AW: [OpenLayers-Users] Feature "style" and layer "styleMap"
Arnd Wippermann
arnd.wippermann at web.de
Tue Aug 30 12:53:08 EDT 2011
I'm not sure, if it's possible to add a default and select style to a
feature.
But you can force the selectControl to use a select style of your choice.
var selectStyle = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['select']);
ctrlSelectFeature.selectStyle=selectStyle;
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von gbrun
Gesendet: Dienstag, 30. August 2011 10:23
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] Feature "style" and layer "styleMap"
Hi everybody!
I've got a question about styles capabilities. I have a layer on which users
can draw features. At this layers, I assigned a "styleMap" property.
When a user has finished drawing a polygon on this layer for example, he can
select this one and change its color. For this, I use the "style"
property of the drawn feature. It works fine, but then, the "styleMap"
property of the layer doesn't apply at this feature anymore. This is a
problem, because the "styleMap" property defines a "select" style: this one
doesn't concern the feature which had its color changed anymore. So the user
can't see if he selected the feature or not! It seems that, if there is a
style applied to a feature, the styleMap isn't taken into account for this
feature anymore.
Does anyone know if there are some conflict between feature "style" and
layer "styleMap"?
Geoffrey
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
