[OpenLayers-Users] WFS GetFeature w/French char in response = null ptr in IE
Michael mdm at yachtpc.com
Wed Aug 31 13:41:00 EDT 2011
Interesting problem.  I wonder whether this is an OpenLayers issue or a
broader XML issue.
Here is a discussion of those pesky non-English characters in XML:
http://www.w3schools.com/xml/xml_encoding.asp
Do you have control of the featureMember's attribute value?  Can you
convert to unicode?
mm
On 8/31/2011 10:37 AM, myOpenLayersUName wrote:
> Hello everyone,
> I am trying to use the OpenLayers.Control.GetFeature with an
> OpenLayers.Protocol.WFS.fromWMSLayer protocol.
> When there is a French character in a featureMember's attribute value the
> selection fails in IE (works in FF) with a null pointer exception because
> the responseText's XML can't be parsed properly. The issue, as far as I can
> tell, is that either the OpenLayers.Request.POST is supposed to indicate
> that the "Content-Type" will be "text/xml; charset=utf-8" rather than just
> "text/xml" or that the OpenLayers.Format.XML read function is supposed to
> attach the proper "Content-Type" somehow (not real clear on that one but it
> seems to be how it is working in FF).
> There doesn't appear to be any way to pass the "Content-Type" config to the
> OpenLayers.Protocol.WFS.v1 read's OpenLayers.Request.POST and I'm leery of
> overriding that read function to force this because I have a feeling it will
> have ramifications beyond just this little problem I'm having for a
> particular layer.
> Has anyone come across this in this area before and, if so, how did you
> avert the null pointer exception?
> Cheers,
> jtm
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-GetFeature-w-French-char-in-response-null-ptr-in-IE-tp6747537p6747537.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
