[OpenLayers-Users] Re: WFS GetFeature w/French char in response
= null ptr in IE
Michael
mdm at yachtpc.com
Wed Aug 31 16:48:36 EDT 2011
Well, I was hoping to suggest the easy path of fixing the issue before
it ever hit OpenLayers
However from your clarification it seems that the issue is that you
cannot correctly set the Content-Type.
In a parallel instance (entirely unrelated) I simply overrode the native
OL function with one that did it MY way. Later submitted it as a bug
fix. Perhaps that might be your best path. In this case, work your way
through the code to see where they set that value, and fix it. You
might even find that someone built in that feature and did not document it!
Michael
On 8/31/2011 10:56 AM, myOpenLayersUName wrote:
> I don't have access to the data, but I may be able to request something be
> changed if necessary.
> However, it is my understanding that the data itself is in Unicode (to
> support the French characters) but that the XML is not being interpreted as
> having a Content-Type of "text/xml; charset=utf-8" but only "text/xml" and,
> consequently, the browser is unable to handle those French characters when
> it sees them as it tries to parse the XML.
> It's entirely possible I'm not understanding your comment though, so please
> feel free to clarify.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-GetFeature-w-French-char-in-response-null-ptr-in-IE-tp6747537p6747608.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
