[OpenLayers-Users] SVG Overlay
hhudson at katmandu.org
Thu Dec 1 18:29:26 EST 2011
Most modern browsers now support adding static svg as <img> tag,
so if your svg is static (no embedded interactivity or external
styling, etc), and will be used in modern browsers, you can treat
it as a normal image. If this is the case, to add your image at
a specific coordinate you might want to consider either, adding a
vector layer with a feature point using your svg specified as the
externalGraphic, or a use a marker layer with your svg as the icon.
Harris.
> Hey all,
> can you please tell me how i can add a "svg overlay", like the one I
> uploaded, on a coordinate?
> http://osgeo-org.1803224.n2.nabble.com/file/n7050997/1005.svg 1005.svg
> Greetings
> http://osgeo-org.1803224.n2.nabble.com/SVG-Overlay-tp7050997p7050997.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
