AW: [OpenLayers-Users] arcgis server wms EPSG:3857 and featureinfo
Morper-Busch, Lucia Lucia.Morper-Busch at sbg.ac.at
Fri Dec 2 07:54:28 EST 2011
Hello,
I solved the display problem of ArcGIS server WMS layers on a spherical
mercator map:
The map projection and the base maps have to be projected in EPSG:3857
(Google layer projection override).
The GeoServer WMS layers support this alias projection anyway.
But what's about the WMSgetFeatureInfo?
I get no result, always the waiting cursor...
Who knows a solution?
Thank you
Lucia
Dipl.-Geogr. Lucia Morper-Busch | Researcher
University of Salzburg | Centre for Geoinformatics - Z_GIS
Schillerstr.30 | Techno-Z, Block 15, 3rd floor, Room 320 | 5020
Salzburg, Austria
Phone +43 (0)662 8044 5298 | Fax +43 (0)662 8044 5260
> Z_GIS...experts for the spatial view <http://www.zgis.at/research>
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von
Morper-Busch, Lucia
Gesendet: Donnerstag, 01. Dezember 2011 11:34
An: openlayers-users at lists.osgeo.org
Betreff: AW: [OpenLayers-Users] spherical mercator aliasprojection 3857
Hello,
now I changed all occurences of 900913 into 3857, overriding the google
layers projection.
All is shown well, except the ArcGIS server WMS layers. The error is
InvalidFormat: Parameter 'width' contains unacceptable value. (but width
is 2494 like all other layers too)
What can I do with the ArcGIS server WMS layers?
Thank you
Lucia
Salzburg, Austria
Morper-Busch, Lucia
Gesendet: Donnerstag, 01. Dezember 2011 11:15
Betreff: [OpenLayers-Users] spherical mercator aliasprojection 3857
Hello,
I have an OL map with projection=EPSG:900913,
displayprojection=EPSG:4326, Google base maps and several WMS layers
provided by GeoServer that supports both projections.
Now I want to add some WMS layers provided by ArcGIS Server with an
aliasprojection=EPSG:3857
I found instructions to override the projection of the base maps with
the aliasprojection. But the result is an InvalidSRS and InvalidFormat
error identical to the previous trial without overriding the projection.
Need I to replace also the projection of the map with the
aliasprojection?
I have to add both types of WMS layers (from GeoServer and ArcGIS
server).
Thank you for suggestions
Lucia
Salzburg, Austria
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111202/5e33bd57/attachment-0001.html
