[OpenLayers-Users] Re: view outside maxExtent
    Jim White
    jbw2003 at earthlink.net
    Mon Dec  5 20:44:54 EST 2011
I solved this myself. In case it is of interest to others, here is what
I needed:
deeds.events.on({
'loadend': function(evt) {
                 console.log("loadend of deeds layer");
                 var deeds_extent = deeds.getDataExtent();
                 map.zoomToExtent(deeds_extent);
                // popup.close();
On 12/02/2011 08:50 AM, Jim White wrote:
> Hi,
> I have a map that I want the initial view to be of a smaller wfs
> layer, but allow the user to view a larger wms layer. If I set the map
> maxExtent to the larger area I can view the all the wms map. If I set
> the maxExtent to the smaller area the initial view is correct, but
> then you cannot view all parts of the larger background map.
> I tried to add
> map.zoomToExtent(new
> OpenLayers.Bounds(-8511523.3718339,4395058.7021558,-8472425.8318731,4416613.9441284));
> However the map always zooms to maxExtent. How to do this?
> Thanks,
> Jim White
