[OpenLayers-Users] poblems with style object in Layers object
Dave Potts
dave.potts at pinan.co.uk
Tue Dec 6 02:48:28 EST 2011
I am having problems with the style object.
If I create a layer with no style object and attempt to access the style
object within a layer, its set to null.
If I look at some of the examples in the exmaples directory from
openlayers 2.11 , it seems to be used in several different ways
highlight-feature.html line 24
Openlayers.Features.Vector.style['default']['strokeWidth']='2'
modify-feature.html line 28
Openlayers.Feature.Vector.style['default']['strokeWidth']='2'
but
osm-layer.html line 54,56
feature.style.OpenLayers.Util.extend({'fill':'black'},
Openlayers.Featurte.Vector.style['default']);
feature.style.strokeWidth=5;
line 63 feature.style.strokeColor="black"
also found at line 25 in resize-feature.html,rotate-features.html
The problem being that in some case 'style' is address as either an hash
or as instance variable.
>From looking at Layer/Vector.js, the style object for the layer is just
described as type object, but from line 809, it can be a Symbolizer?
So I am confused what should the type of the style object should from the
Layer/Vector.js, it can be
A. A single style object?
B. A hash of style objects?
C. A Symboolizer?
While I am at it there seems to be a style2 object defined as well, but
from the documentation, I am confused as to when I should use Style2
instead of Style
regards
Dave.
Regards
Dave.
