AW: [OpenLayers-Users] points bouncing on their coordinates
Arnd Wippermann
arnd.wippermann at web.de
Tue Dec 6 16:52:40 EST 2011
Add projection to the map options.
By default it is EPSG:4326 and somehow it is possible in one map to mix
EPSG:4326 and EPSG:900913.
map = new OpenLayers.Map('mapa',{
projection:new OpenLayers.Projection("EPSG:900913"),
controls: [
new OpenLayers.Control.Navigation(),
//new OpenLayers.Control.ScaleLine(),
new OpenLayers.Control.KeyboardDefaults(),
new OpenLayers.Control.PanZoom()],
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von vrbikdan
Gesendet: Dienstag, 6. Dezember 2011 22:22
An: users at openlayers.org
Betreff: [OpenLayers-Users] points bouncing on their coordinates
Hi all,
I'm trying to make map with some points so I defined this points in code
with their coordinates, but problem is, when I try to pan with the map. This
points doesn't stay in their locations and moving some around. I can't
figure it out, where is problem. Aplication is here:
http://vrbikdan.xf.cz/blom/mapa.html# http://vrbikdan.xf.cz/blom/mapa.html#
and part of the code here:
var featurecollection = {
"type": "FeatureCollection",
"features":[
{"type":"Feature","geometry":{"type":"Point","coordinates":[19.21,43.23]},"i
d":"1",
"loc_name":"Desna",
"x_coor":"16.1",
"y_coor":"42.8",
"z_coor":"300",
"municip":"x",
"watershed":"x",
var geojson_format = new OpenLayers.Format.GeoJSON();
var HydroelLayer = new OpenLayers.Layer.Vector();
map.addLayer(HydroelLayer);
HydroelLayer.addFeatures(geojson_format.read(featurecollection));
Thanks a lot
Dan
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/points-bouncing-on-their-coordinates-
tp7068441p7068441.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
