[OpenLayers-Users] Tweening pinpoints
Takako Tucker Takako.Tucker at bbc.co.uk
Wed Dec 7 09:21:13 EST 2011
Hi Casper
Do you happen to have any example page for pinpoint animation? I know
this is the tweening for the whole map and not pinpoint.
Takako
From: Casper Span [mailto:info at spatially-oriented.com]
Sent: 07 December 2011 10:38
To: Takako Tucker
Cc: Adam Eskreis; openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Tweening pinpoints
I dabbled a bit with this a few weeks ago and posted a small blog on
it... Maybe it helps.
http://www.spatially-oriented.com/joomla/tech/34-gis-articles/59-animate
d-zoom-with-openlayers
On Wed, Dec 7, 2011 at 10:55 AM, Takako Tucker <Takako.Tucker at bbc.co.uk>
wrote:
	Thanks for this! I had a look at .Tween, but as it reacts to DOM
elements I couldn't be sure if it works with Lon Lat (X.Y) figure.
	I'll try again later on though.
	Sent: 06 December 2011 18:03
	To: Takako Tucker
	Cc: openlayers-users at lists.osgeo.org
	There is an OpenLayers.Tween class I believe.
	Also, this is something that could easily be done iwth just
regular javascript.  Don't forget, OpenLayers is comprised of DOM
elements, so you can manipulate the map with regular javascript, you
don't have to use an OpenLayers construct.
	On Tue, Dec 6, 2011 at 12:33 PM, Takako Tucker
<Takako.Tucker at bbc.co.uk> wrote:
		Hello,
		I'm currently using OpenLayers.Control.DragFeature to
move pinpoint from one place to another.
		        var dragFeature = new
OpenLayers.Control.DragFeature(location);
		                         map.addControl(dragFeature);
		                         dragFeature.activate();
		But not only moving pinpoints, I need to add tween
animation.
		Has anyone done tween animation for moving pinpoints?
		Any advise would be much appreciated!
		Thanks
		Takako
		http://www.bbc.co.uk
		This e-mail (and any attachments) is confidential and
may contain personal views which are not the views of the BBC unless
specifically stated.
		If you have received it in error, please delete it from
your system.
		Do not use, copy or disclose the information in any way
nor act in reliance on it and notify the sender immediately.
		Please note that the BBC monitors e-mails sent or
received.
		Further communication will signify your consent to this.
		Users mailing list
		Users at lists.osgeo.org
		http://lists.osgeo.org/mailman/listinfo/openlayers-users
	This e-mail (and any attachments) is confidential and may
	If you have received it in error, please delete it from your
system.
	Do not use, copy or disclose the information in any way nor act
	Please note that the BBC monitors e-mails sent or received.
	Users mailing list
This e-mail (and any attachments) is confidential and may contain
personal views which are not the views of the BBC unless specifically
stated.
If you have received it in error, please delete it from your system.
Do not use, copy or disclose the information in any way nor act in
http://www.bbc.co.uk/
This e-mail (and any attachments) is confidential and may contain personal views which are not the views of the BBC unless specifically stated.
Do not use, copy or disclose the information in any way nor act in reliance on it and notify the sender immediately.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111207/9bc8c089/attachment-0001.html
