[OpenLayers-Users] Select feature on multiple layers works just for one layer
Andreas Hocevar ahocevar at opengeo.org
Wed Dec 7 11:49:19 EST 2011
for features that sit on top of each other, you will only get events
for the top one. Sounds like this is the reason for your problem.
Andreas.
On Sun, Dec 4, 2011 at 9:05 PM, Diego Pasqualin <dpasqualin at gmail.com> wrote:
> Oh, I forgot to put this part of the code, which is run just after the
> previous code:
> ---------------------------8<----------------------------------------------------------------------
>         entities.layer_office.events.on({
>             'featureselected': function (e) {onFeatureSelect(e.feature,
> entity.map, control)},
>             'featureunselected': function (evt)
> {onFeatureUnselect(evt.feature, entity.map) }
> ... the same for suburbs.suburbs_layer...
> So, I create the control with the layers I want, and after that I use the
> layers.events.on to run something when the a feature is selected.
> This is practically the same I saw in some examples. What could be wrong?
> 2011/12/3 emmexx <emmexx at tiscalinet.it>
>> Il 12/02/2011 01:45 AM, Diego Pasqualin scrisse:
>> > Any suggestion about what I might be doing wrong?
>> Try using eventListeners instead of OnSelect?
>> Or layer.events.on().
>> Bye
>>        maxx
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
