[OpenLayers-Users] Tweening pinpoints
Takako Tucker Takako.Tucker at bbc.co.uk
Thu Dec 8 10:50:27 EST 2011
Hi Casper
This is it:
http://paste.ideaslabs.com/show/z8cOKJZr1X
I got rid of the error so no errors, but tweening is not working.
It's partly dependant to our own API so it'll throw some errors if you
set it up on your sandbox etc...
I'm just hoping I'm missing something very simple that you could spot
straight away...
I'll keep working on it.. Thanks for your help!!
Takako
From: Casper Span [mailto:info at spatially-oriented.com]
Sent: 08 December 2011 15:24
To: Takako Tucker
Cc: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Tweening pinpoints
Perhaps you could share parts of your code and the error you are
getting?
I think that will be more efficient then you having to recode another
example :)
Casper
On Thu, Dec 8, 2011 at 2:59 PM, Takako Tucker <Takako.Tucker at bbc.co.uk>
wrote:
	Hi Casper
	Do you think you could put up an example page somewhere for
moving pinpoints?
	I've put the code in, but throws an error which I'm struggling
to get rid of!
	I've been having a look at this one too
http://openlayers.org/dev/tests/manual/tween.html
<http://openlayers.org/dev/tests/manual/tween.html>
	but not luck converting this into my code.
	Takako
	Sent: 07 December 2011 20:56
	To: Takako Tucker
	Cc: Adam Eskreis; openlayers-users at lists.osgeo.org
	Hi Takako,
	In my example I wanted the map to move.
	However, it should be fairly easy to adapt the code to your
liking.
	Basically what I do is letting the tween class calculate my path
& timing, and on eachStep I move the map. On eachStep, you should move
your pinpoint with something like this: (NOTE: not tested)
	someFunc: function() {
	// var fromCoord = your starting point
	// var toCoord = your destination point
	// var duration = number of steps it should take, the more you
take, the smoother the ride & longer it will take. (unless you also
change the INTERVAL constant on Tween)
	var callbacks = {
	   eachStep: tweenstep
	var tween = new
OpenLayers.Tween(OpenLayers.Easing.Quad.easeInOut);
	tween.start(fromCoord, toCoord, duration, {callbacks: callbacks}
	tweenstep: function (value) {
	  // TODO: move your feature to the new coord
	  // given in value.x and value.y
	And another note: the tweenstep function is being called from
the tween class, so you are out of scope and cannot see your feature.
That's why, in my blogpost, I also stored the map object into the tween.
You will probably have to do something similar with your feature.
	If you can't get this to work, I might be able to set up a
sample somewhere. Also, you might have some luck looking at the
developer example code:
	regards,
	Casper
	On Wed, Dec 7, 2011 at 6:39 PM, Takako Tucker
<Takako.Tucker at bbc.co.uk> wrote:
		Hi, so this is what I currently got.
		http://paste.org/41978
		I can't seem to see Tweening working between
pinpoints... Any advise would be much appreciated.
		The map shouldn't move and just pinpoints should move...
		Takako
		Sent: 07 December 2011 10:38
		To: Takako Tucker
		I dabbled a bit with this a few weeks ago and posted a
small blog on it... Maybe it helps.
http://www.spatially-oriented.com/joomla/tech/34-gis-articles/59-animate
d-zoom-with-openlayers
		On Wed, Dec 7, 2011 at 10:55 AM, Takako Tucker
			Thanks for this! I had a look at .Tween, but as
it reacts to DOM elements I couldn't be sure if it works with Lon Lat
(X.Y) figure.
			I'll try again later on though.
			Sent: 06 December 2011 18:03
			To: Takako Tucker
pinpoints
			There is an OpenLayers.Tween class I believe.
			Also, this is something that could easily be
done iwth just regular javascript.  Don't forget, OpenLayers is
comprised of DOM elements, so you can manipulate the map with regular
javascript, you don't have to use an OpenLayers construct.
			On Tue, Dec 6, 2011 at 12:33 PM, Takako Tucker
				Hello,
				I'm currently using
OpenLayers.Control.DragFeature to move pinpoint from one place to
another.
				        var dragFeature = new
OpenLayers.Control.DragFeature(location);
map.addControl(dragFeature);
dragFeature.activate();
				But not only moving pinpoints, I need to
add tween animation.
				Has anyone done tween animation for
moving pinpoints?
				Any advise would be much appreciated!
				Thanks
				Takako
				http://www.bbc.co.uk
				This e-mail (and any attachments) is
confidential and may contain personal views which are not the views of
the BBC unless specifically stated.
				If you have received it in error, please
delete it from your system.
				Do not use, copy or disclose the
information in any way nor act in reliance on it and notify the sender
immediately.
				Please note that the BBC monitors
e-mails sent or received.
				Further communication will signify your
consent to this.
				Users mailing list
				Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
			If you have received it in error, please delete
			Do not use, copy or disclose the information in
any way nor act in reliance on it and notify the sender immediately.
			Please note that the BBC monitors e-mails sent
or received.
			Further communication will signify your consent
to this.
			Users mailing list
		This e-mail (and any attachments) is confidential and
may contain personal views which are not the views of the BBC unless
		If you have received it in error, please delete it from
your system.
		Do not use, copy or disclose the information in any way
		Please note that the BBC monitors e-mails sent or
received.
		Further communication will signify your consent to this.
your system.
received.
	This e-mail (and any attachments) is confidential and may
	If you have received it in error, please delete it from your
system.
	Do not use, copy or disclose the information in any way nor act
	Please note that the BBC monitors e-mails sent or received.
http://www.bbc.co.uk/
This e-mail (and any attachments) is confidential and may contain personal views which are not the views of the BBC unless specifically stated.
If you have received it in error, please delete it from your system.
Do not use, copy or disclose the information in any way nor act in reliance on it and notify the sender immediately.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111208/908db873/attachment.html
