[OpenLayers-Users] Re: Questions about Filtering WFS
Phil Scadden p.scadden at gns.cri.nz
Thu Dec 8 15:50:36 EST 2011
On 8/12/2011 6:02 p.m., Diego M. wrote:
> *Strongly consider using WMS to display and WFS to query instead. *
> is there any example to explane how to do that ?
Add the layer to the map as a WMS layer styled with a SLD. A simple
query (click on the object) can be done then wmsgetfeature (see OL
examples). For polygon, within-radius-of-click, text search,
you create a wfsProtocol object, set the appropriate filter (polygon,
dwithin or a logically query depending on application) and do  a read on
the protocol, with a call back to process the result.
Look at examples and search mailing list for wfsprotocol.
> *You need to convert the distance into native projection (application
> knowledge). *
> also how i can do that ?
> I'm really stuck here.
Something like:
pt1 = e.features.geometry; // assuming you are doing this a registered event
pt2 = pt1.clone();
pt2.x += myDistance // in display projection units)
pt1.transform(displayprojection, nativeproject);
pt2.trasnform(displayprojection, nativeproject);
myDistance = Math.abs(pt1.x-pt2.x);
However, you need to know what native projection is. Get that from the
server.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
