[OpenLayers-Users] Retrieve lat/lon coordinates
canduc17
candini at meeo.it
Fri Dec 16 06:32:08 EST 2011
Hi everyone.
I have an OSM style map produced with http://mapnik.org/ mapnik , having
projection http://spatialreference.org/ref/epsg/31258/ EPSG:31258 .
To perform tile production I have specified to mapnik my projection, so they
should have been produced correctly.
My code is the following:
The map is correctly rendered and the tiling system works.
But I have two questions:
1 - How can I retrieve lat/lon coordinates passing with the cursor on the
map? Like in http://openlayers.org/dev/examples/mouse-position.html this
example , but I would like to obtain lat/lon and not x/y coordinates...
2 - The setCenter function doesn't work: map is focused in the Atlantic
Ocean and not ove Salzburg as expected.
Thanks in advance.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Retrieve-lat-lon-coordinates-tp7100457p7100457.html
