[OpenLayers-Users] getProjection() retrieve different projection than the one expected
Fernando fnorte at gmail.com
Tue Dec 20 06:43:51 EST 2011
2011/12/20 fnorte
U forget the codes
2011/12/20 canduc17 <candini at meeo.it>
Which codes?
A more detailed and comprehensive answer would be appreciated.
> I have defined my map in the following way:
Which way?
> and I have added to my html the projection reference and proj library:
How did u do it?
> The problem is that if I retrieve map projection with:
With what?
> I get
Get what?
> and not
Not What?
> as expected.
> Can someone explain me why?
Maybe it's easier to give a "more detailed and comprehensive answer" if you
show the codes to see what is the problem...
Att,
Fernando G. Norte
BHte - MG
cel: +55 31 9119 8814
MSN e Gtalk # fnorte at gmail.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111220/22e35313/attachment.html
