[OpenLayers-Users] id of a marker
Puneet Kishor
punk.kish at gmail.com
Tue Dec 27 16:51:56 EST 2011
On Dec 27, 2011, at 3:41 PM, Cúmar Cueva wrote:
> Maybe there's something wrong, but is necessary show the way how you're
> creating the markers and getting the id in your code. Do you have a simple
> case?
var markerLayer = new OpenLayers.Layer.Markers( "Markers" );
map.addLayer(markerLayer);
var size = new OpenLayers.Size(21, 25);
var offset = new OpenLayers.Pixel(-(size.w / 2), -size.h);
var icon = new OpenLayers.Icon('http://path/to/marker.png', size, offset);
var marker = new OpenLayers.Marker(
new OpenLayers.LonLat(x, y).transform(
proj.latlng,
proj.google
icon
marker.id = "my_custom_id";
markerLayer.addMarker(marker);
The above code does set a marker attribute called "id" to "my_custom_id", but I can't use it to get that DOM element. For example, the following doesn't work
var elem = document.getElementById(marker.id);
do something with 'elem'
> 2011/12/27 Puneet Kishor <punk.kish at gmail.com>
>> On Dec 27, 2011, at 3:02 PM, Cúmar Cueva wrote:
>>> I don't remember if by default a maker has an 'id',
>> When I create a marker, it gets a programmatically generated id, for
>> example, id="OL_Icon_207"
>>> but if you have created
>>> a maker with a explicit 'id' as:
>>> var marker = new OpenLayers.Marker(LatLon, Icon);
>>> marker.id = 'myId001';
>>> then, you can get this value using the simple way:
>>> marker.id
>> Using the technique above does nothing. I don't think it sets the DOM id
>> of the marker element.
>>>> I am wondering if I can get the id of a marker that I just created.
>>>> Unfortunately, `marker.id` is not a property. Suggestions?
>>>> Puneet Kishor
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Atte,
> Cúmar Cueva
