[OpenLayers-Users] New WFS layer will draw until map is zoomto[problem trace to inacitve BBox object]
Dave Potts dave.potts at pinan.co.uk
Thu Dec 29 14:35:32 EST 2011
On 27/12/11 13:13, Dave Potts wrote:
Problem discovered, my BBox stratgy was shared between two different
layers, with the result that its internal state got corrupted.
> On 26/12/11 20:00, Dave Potts wrote:
> After a lot off digging around in the source code, it seem my refresh
> attempt generates a moveend event.
> Which is then ignore by my BBOx stratgy, because the BBoxstratgy is not
> active, therefore it has not installed a callback handler
> Setting the BBoxstratgy to active results in an error 'this.layer' is
> null :-(
> So different question
> How do I ensure that the BBox stratgy is always in an active state?
>> HI List
>> A slight problem with the WFS layer functions
>> I am trying to add a new WFS layer to my map when I hit a gwt  button, I
>> am using openlayers via the gwt plugin in.
>> I add a single wfs layer, when my button selected I make another request
>> to load a wfs layer.
>> I get the callbacks to say that layer has been loaded, but nothing is
>> displayed on the screen. If I zoom in, a update event occurs, and the
>> missing layer is drawn.
>> Q. When I load a 2nd WFS layer shown it be drawn then the endloading
>> callback is fired ?
>> Q. What is the offical way of refreshing a screen after a layer has been
>> loaded?
>> So far I have attempt to refresh the screen by
>> 1. Calling the redraw call on the new layer.
>> 2. Zooming to the maxevents of the new layer.
>> 3. Using a refresh stratgy
>> 4. Zoom to the current maginfcation.
>> None of this attempts worked.
>> The only proven way of doing it seems to be zoom in one increment.
>> Dave
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
