[OpenLayers-Users] Problem with GetFeature Control
Julio Vega
oilagex at gmail.com
Fri Feb 11 02:07:37 EST 2011
Hi I want to use the GetFeature control in a fresh mapfish app. I have
configured the protocol of the control, and added a WMS as a simple base
layer with the same projection and displayprojection ("EPSG;4326"). I use
geoserver.
With firebug I have seen that the control does the WFS POST request to
geoserver, and geoserver gives back the gml document (I think then the proxy
is not the problem because I can get the geographical features, I put the
application inside geoserver folder in apache), the problem comes with the
featuresselected event because I have put into the event an alert and it
doesn't show, I paste the code here, for any further reference. (I get it
from the official mapfish documentation). What could be wrong?.
I thank your time and attention.
Thank you very much.
var featureControl = new OpenLayers.Control.GetFeature({
//strategies: [new OpenLayers.Strategy.BBOX()],
protocol: new OpenLayers.Protocol.WFS({
version: "1.1.0",
url: "http://localhost:8080/geoserver/wfs",
featureType: "ways",
featureNS: "simulador",//
http://localhost:8080/geoserver/rest/proxy?url=simulador.trafico
srsName: "EPSG:4326",
maxFeatures:50
box: true,
hover: true,
multipleKey: "shiftKey",
toggleKey: "ctrlKey",
multiple: true,
allowSelection:true
*//I have tried this way*
featureControl.events.on({
'featuresselected': function(e){
alert('dfsfds');
* //And also this way*
featureControl.events.register("featuresselected", this,
function(e) {
alert("lkjlk");
selectLayer.addFeatures([e.feature]);
featureControl.events.register("featureunselected", this,
function(e) {
alert("lkjlk");
selectLayer.removeFeatures([e.feature]);
featureControl.events.register("hoverfeature", this, function(e)
alert("lkjlk");
hoverLayer.addFeatures([e.feature]);
featureControl.events.register("outfeature", this, function(e) {
alert("lkjlk");
hoverLayer.removeFeatures([e.feature]);
//map.addControl(featureControl);
//featureControl.activate();
//This is the actions array for the toolbar
actions.push(new GeoExt.Action({
iconCls: "info",
map: map,
toggleGroup: "map",
tooltip: "Get country information",
control: featureControl
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110211/5216ce17/attachment.html
