AW: [OpenLayers-Users] Re: AW: Re: adding KML file
Sarah Schuessler sarah_flip at yahoo.de
Fri Feb 11 08:07:58 EST 2011
if you use a overlay layer with epsg 4326 and base layer(google) with epsg
900913 you have to transform or projection (proj4) client side.
You don´t use spericalMercator: true at the moment.
HTH
Sarah
Von: vrbikdan <vrbikdan at gmail.com>
An: openlayers-users at lists.osgeo.org
Gesendet: Freitag, den 11. Februar 2011, 13:45:27 Uhr
Betreff: [OpenLayers-Users] Re: AW: Re: adding KML file
Arnd Wippermann <arnd.wippermann at ...> writes:
> Most likely you use a commercial layer (Google, VE,...) with a map
> projection EPSG:4326 instead of sphericalMercator EPSG:900913.
> Arnd
No, every projection I use do the same. Coordinates aren't right, lines
aren't in places where it should be and moving with me, when I want to
pan north or south. I'm not sure, if I can explain it correctly, so if
you want http://dvphoto.xf.cz/dp/dp.html I'm using google maps as base
layer and now is projection WGS84 (epsg: 4326).
thanks for helping
dan
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110211/8994bae6/attachment.html
