[OpenLayers-Users] Transformation Problem
Andrés Maneiro
amaneiro at icarto.es
Wed Feb 16 05:05:57 EST 2011
Frederick, I think you have to use proj4js to transformations (except
for the EPSG:43206 & EPSG:900913, which are supported by default):
http://trac.osgeo.org/openlayers/wiki/Documentation/Dev/proj4js
amaneiro
On 16/02/11 10:31, Frederick Löbig wrote:
> Hey there,
> I have a serious problem with a simple coordinate transformation. The
> Problem is, that the source coordinates won't be transformed. The result
> is a coordinate-pair similar to the source coordinates. This is my code:
> var target = new OpenLayers.LonLat(split_lon,split_lat) ; //split_lon =
> 8.6108243631697 , split_lat = 50.126971489974, this is also the result
> var source_proj = new OpenLayers.Projection("EPSG:900913") ;
> var target_proj = new OpenLayers.Projection("EPSG:31467") ;
> var transformed_coords = target.transform(source_proj,target_proj);
> I have also tried to use the maps projection-object as target-projection
> but with no success. Why is that?
> Best,
> Freddy
> **Frederick Löbig*
> Röderichstraße 59
> 60489 Frankfurt am Main
> E:: Frederick.Loebig at grunsnid.de <mailto:Frederick.Loebig at grunsnid.de>
> P: +49 (0) 69 - 78 99 52 41
> M: +49 (0) 174 - 70 89 296
> *Office:*
> *euNetworks GmbH*
> Ludwig-Landmann-Straße 405
> 60486 Frankfurt am Main
> P: +49 (0) 69 - 90 554 - 532
> E: Frederick.Loebig at eunetworks.com <mailto:Frederick.Loebig at eunetworks.com>
> S: floebig
> This email and any attachments may contain confidential and/or legally
> privileged information. If you are not the intended recipient, please
> delete the email without reading it and notify the sender.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
