[OpenLayers-Users] cluster strategy
Mihai Visan
misuvn at gmail.com
Wed Feb 16 09:54:54 EST 2011
Hi Paul,
from what I know about OpenLayers your code is what I'm looking for, but I can't make the event working. What is interesting is that if I change what is with red it deactivate cluster strategy no matter the zoom level.
map.events.register("move", null, function() { // #2, #3 respond to map extent change
// disable cluster when zoom greater than threshold
if (map.getZoom() < clusterMaxZoom) { // #2.1 how to read current zoom
clusterStrategy.deactivate(); // #2.2 how to disable cluster strategy
} else {
clusterStrategy.activate();
Help me please.
Here is my code:
<html>
<head>
<title>OpenLayers Test</title>
<script type="text/javascript" src="js/OpenLayers.js"></script>
<script defer="defer" type="text/javascript">
function init(){
// styles for cluster strategy
var style = new OpenLayers.Style({
fillColor: "${fill_color}",
fillOpacity: 0.4,
pointRadius: "${radius}",
strokeColor: "${stroke_color}",
strokeOpacity: 1,
strokeWidth: 1
context: {
radius: function(feature) {
var pix = 8;
if(feature.cluster) {
pix = Math.min(feature.attributes.count, 11) + 8;
return pix;
fill_color: function(feature) {
maxImportance = 0;
for(var c = 0; c < feature.cluster.length; c++) {
i = feature.cluster[c].attributes.importance;
if(i > maxImportance) {
maxImportance = i;
mainFeature = c;
feature.attributes.fillColor = feature.cluster[mainFeature].attributes.fillColor;
return feature.attributes.fillColor;
stroke_color: function(feature) {
maxImportance = 0;
maxImportance = i;
mainFeature = c;
feature.attributes.strokeColor = feature.cluster[mainFeature].attributes.strokeColor;
return feature.attributes.strokeColor;
/* Creating the Map Viewer */
/*In order to create the viewer, you must first create a map. The OpenLayers.Map constructor requires one argument: This argument must either be an HTML Element, or the ID of an HTML element. This is the element in which the map will be placed.*/
var map = new OpenLayers.Map("map", {
controls: [
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanPanel(),
new OpenLayers.Control.ZoomPanel(),
new OpenLayers.Control.LayerSwitcher() /* Open the switch layers panel */
maxResolution: 'auto',
numZoomLevels: 6 // maximum zoom
/*Map Constructor*/
/* The next step to creating a viewer is to add a basic layer to the Map. */
var basicMapLayer = new OpenLayers.Layer.Image(
"Map Image",
"images/maps/MapImage.jpg",
new OpenLayers.Bounds(0, 0, 510, 510),
new OpenLayers.Size(510, 510)
/* Adding an Multipoint Vector Layer with cluster strategy */
var clusterStrategy = new OpenLayers.Strategy.Cluster({distance: 20});
var monuments = new OpenLayers.Layer.Vector("Monuments", {
strategies: [clusterStrategy],
styleMap: new OpenLayers.StyleMap({"default": style})
// cluster threshold
var clusterMaxZoom = 2; // maximum zoom is 6
if (map.getZoom() > clusterMaxZoom) { // #2.1 how to read current zoom
} else {
var point_1 = new OpenLayers.Geometry.Point(270, 205);
var point_1_Feature = new OpenLayers.Feature.Vector(point_1);
point_1_Feature.attributes = {
strokeColor: "#ffffff",
fillColor: "#ffffff",
importance: 9
var point_2 = new OpenLayers.Geometry.Point(263, 201);
var point_2_Feature = new OpenLayers.Feature.Vector(point_2);
point_2_Feature.attributes = {
strokeColor: "blue",
fillColor: "blue",
importance: 3
var point_3 = new OpenLayers.Geometry.Point(260, 202);
var point_3_Feature = new OpenLayers.Feature.Vector(point_3);
point_3_Feature.attributes = {
strokeColor: "yellow",
fillColor: "yellow",
importance: 5
var point_4 = new OpenLayers.Geometry.Point(261, 202);
var point_4_Feature = new OpenLayers.Feature.Vector(point_4);
point_4_Feature.attributes = {
importance: 5
var point_5 = new OpenLayers.Geometry.Point(263, 202);
var point_5_Feature = new OpenLayers.Feature.Vector(point_5);
point_5_Feature.attributes = {
importance: 5
/* Layer Constructor */
/* In order to display the map, you must set a center and zoom level. In order to zoom to fit the map into the window, you can use the zoomToMaxExtent function, which will zoom as close as possible while still fitting the full extents within the window. */
map.addLayers([basicMapLayer, monuments]);
map.zoomToMaxExtent();
// features for layer with cluster strategy must me declared after layer is added in order to work
var monumentsFeature = new OpenLayers.Feature.Vector(
new OpenLayers.Geometry.MultiPoint([point_1, point_2, point_3, point_4, point_5])
monuments.addFeatures([point_1_Feature, point_2_Feature, point_3_Feature, point_4_Feature, point_5_Feature]);
// end of init function
</script>
</head>
<body onLoad="init()">
<div style="width:100%; height:100%; border:#000 1px solid; background:#000000;" id="map"></div>
</body>
</html>
-----Original Message-----
Sent: Wednesday, February 16, 2011 3:37 PM
To: Mihai Visan
Cc: OpenLayers User list
Subject: Re: [OpenLayers-Users] cluster strategy
I don't know your code but I would assume that you are looking for something like this:
var map = new OpenLayers.Map('mapDiv', mapOptions);
var clusterStrategy = new OpenLayers.Strategy.Cluster(clusterOptions);
var layerOptions = {
var vectorLayers = new OpenLayers.Layer.Vector('features', layerOptions);
var clusterMaxZoom = 10;
map.events.register('move', null, function() { // #2, #3 respond to map extent change
} else {
// filter features based on bounding box
var extent = map.getExtent(); // #3.1
// reload features here, it depends on how you read your features in now
If you are not using a Protocol like WFS () with your layer then the BBOX strategy will have no effect and you will have to manually reload features using whatever mechanism you are using now.
Cheers
Paul
On 2011-02-16, at 7:58 AM, Mihai Visan wrote:
> Thanks Paul,
> I already read the documentation and all tutorial and user discusions I could found.
> But I'm a week at javascript, so I could use some examples or tutorials I could transform
> -----Original Message----- From: Paul Spencer
> Sent: Wednesday, February 16, 2011 2:43 PM
> To: Mihai Visan
> Mihai, all of your questions have answers in the documentation ...
> On 2011-02-16, at 7:29 AM, Mihai Visan wrote:
>> 2. disable cluster strategy at certain zoom level.
>> Problems: 2.1. I don’t know how to read current zoom
> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.getZoom
>> 2.2. I don’t know to disable cluster strategy
> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Strategy/Cluster-js.html#OpenLayers.Strategy.Cluster.deactivate
>> 3. use (BBOX strategy and) ajax to disable features outside visible bounds
>> Problems: 3.1. I don’t know how to read visible bounds
> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.getExtent
>> 3.2. I don’t know how to integrate ajax with (BBOX and) mouse drag or zoom in/out
> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.EVENT_TYPES
> Cheers
> Paul
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110216/866ce613/attachment-0001.html
