[OpenLayers-Users] SingleFile.js - small improvement in RegExp of function _getScriptLocation
Andreas Neumann
a.neumann at carto.net
Wed Feb 16 11:45:53 EST 2011
Hi Eric,
Thank you for the hint - I'll go with option two.
Andreas
On Tue, 15 Feb 2011 09:03:11 +0100, Eric Lemoine wrote:
> On Mon, Feb 14, 2011 at 5:51 PM, Andreas Neumann
> <a.neumann at carto.net> wrote:
>> Hi,
>> While trying to optimize OpenLayers for deployment I noticed that
>> OpenLayers
>> fails if the file is named OpenLayers.js.gz instead of just
>> OpenLayers.js
>> It is simple to fix:
>> In file SingleFile.js, in function _getScriptLocation change:
>> old:
>> var r = new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),
>> s = document.getElementsByTagName('script'),
>> src, m, l = "";
>> new:
>> var r = new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\.gz)*(\\?|$)"),
>> src, m, l = "";
>> note the additional '(\.gz)*'
>> Could this be included in trunk so one can use either OpenLayers.js
>> or
>> OpenLayers.js.gz?
>> see ticket http://trac.osgeo.org/openlayers/ticket/3060
> Hi
> I can see two alternatives.
> #1 Write your own SingleFile.js:
> var OpenLayers = {
> _getScriptLocation: function() {
> return "path to your OpenLayers.js.gz";
> #2 Do the following:
> - In your page's head add a <link> tag to OpenLayers'
> theme/default/style.css file,
> - Pass theme:null to the Map (and the OverviewMap)
> - Set OpenLayers.imgPath to the path to OpenLayers' img dir
> With these things OpenLayers won't need _getScriptLocation at all.
> I'd recommend #2.
> Cheers,
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
