[OpenLayers-Users] cluster strategy - MANY THANKS !!!
Mihai Visan
misuvn at gmail.com
Thu Feb 17 06:48:07 EST 2011
Many thanks and kisses Paul, you saved me.
(I was able to create activate() function using your example.)
here is the final code for all who are interested in optimizing cluster
strategy:
<html>
<head>
<title>Cluster</title>
<script src="js/lib/Firebug/firebug.js"></script>
<script type="text/javascript" src="js/OpenLayers.js"></script>
<script defer="defer" type="text/javascript">
function init(){
// styles for cluster strategy
var style = new OpenLayers.Style({
fillColor: "${fill_color}",
fillOpacity: 0.4,
pointRadius: "${radius}",
strokeColor: "${stroke_color}",
strokeOpacity: 1,
strokeWidth: 1
context: {
radius: function(feature) {
var pix = 8;
if(feature.cluster) {
pix = Math.min(feature.attributes.count, 11)
+ 8;
return pix;
fill_color: function(feature) {
maxImportance = 0;
for(var c = 0; c <
feature.cluster.length; c++) {
i =
feature.cluster[c].attributes.importance;
if(i > maxImportance) {
maxImportance = i;
mainFeature = c;
feature.attributes.fillColor =
feature.cluster[mainFeature].attributes.fillColor;
return feature.attributes.fillColor;
stroke_color: function(feature) {
maxImportance = 0;
for(var c = 0; c <
i =
maxImportance = i;
mainFeature = c;
feature.attributes.strokeColor =
feature.cluster[mainFeature].attributes.strokeColor;
return feature.attributes.strokeColor;
/* Creating the Map Viewer */
/*In order to create the viewer, you must first create a map. The
OpenLayers.Map constructor requires one argument: This argument must either
be an HTML Element, or the ID of an HTML element. This is the element in
which the map will be placed.*/
var map = new OpenLayers.Map("map", {
controls: [
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanPanel(),
new OpenLayers.Control.ZoomPanel(),
new OpenLayers.Control.LayerSwitcher() /* Open the switch
layers panel */
maxResolution: 'auto',
numZoomLevels: 6 // levels of zoom
/*Map Constructor*/
/* The next step to creating a viewer is to add a basic layer to the
Map. */
var basicMapLayer = new OpenLayers.Layer.Image(
"Map Image",
"images/maps/MapImage.jpg",
new OpenLayers.Bounds(0, 0, 510, 510),
new OpenLayers.Size(510, 510)
/* Adding an Multipoint Vector Layer with cluster strategy */
var clusterStrategy = new OpenLayers.Strategy.Cluster({
distance: 20,
deactivate: function() {
var deactivated =
OpenLayers.Strategy.prototype.deactivate.call(this);
if(deactivated) {
var features = [];
var clusters = this.layer.features;
for (var i=0; i<clusters.length;
i++) {
var cluster = clusters[i];
if (cluster.cluster) {
for (var j=0;
j<cluster.cluster.length; j++) {
features.push(cluster.cluster[j]);
} else {
features.push(cluster);
this.layer.removeAllFeatures();
this.layer.events.un({
"beforefeaturesadded":
this.cacheFeatures,
"moveend": this.cluster,
scope: this
this.layer.addFeatures(features);
this.clearCache();
return deactivated;
var activated =
OpenLayers.Strategy.prototype.activate.call(this);
if(activated) {
var features = [];
i++) {
for (var j=0;
} else {
this.layer.events.on({
this.cacheFeatures,
scope: this
this.clearCache();
return activated;
var monuments = new OpenLayers.Layer.Vector("Monuments", {
strategies: [clusterStrategy],
styleMap: new OpenLayers.StyleMap({"default":
style})
// cluster threshold
var clusterMaxZoom = 0; // maximum zoom level is 5. Zoom level start at
0.
map.events.register("move", null, function() { // respond to map extent
change
var zoom = map.getZoom();
console.log('zoom is ' + zoom);
// disable cluster when zoom greater than threshold
if (zoom > clusterMaxZoom) { // read current zoom
clusterStrategy.deactivate(); // disable cluster strategy
//clusterStrategy.clearCache(); // clear cluster cache
console.log('deactivate cluster');
} else {
clusterStrategy.activate(); // disable cluster strategy
console.log('activate cluster');
//here is a hint:
// filter features based on bounding box
var extent = map.getExtent(); // how to read visible bounds
// reload features here, it depends on how you read your features in now
// If you are not using a Protocol like WFS () with your layer then the BBOX
strategy will have no effect and you will have to manually reload features
using whatever mechanism you are using now.
// create vector points to be added to layer
var point_1 = new OpenLayers.Geometry.Point(270, 205);
var point_1_Feature = new OpenLayers.Feature.Vector(point_1);
point_1_Feature.attributes = {
strokeColor: "#ffffff",
fillColor: "#ffffff",
importance: 9
var point_2 = new OpenLayers.Geometry.Point(263, 201);
var point_2_Feature = new OpenLayers.Feature.Vector(point_2);
point_2_Feature.attributes = {
strokeColor: "blue",
fillColor: "blue",
importance: 3
var point_3 = new OpenLayers.Geometry.Point(260, 202);
var point_3_Feature = new OpenLayers.Feature.Vector(point_3);
point_3_Feature.attributes = {
strokeColor: "yellow",
fillColor: "yellow",
importance: 5
var point_4 = new OpenLayers.Geometry.Point(261, 202);
var point_4_Feature = new OpenLayers.Feature.Vector(point_4);
point_4_Feature.attributes = {
importance: 5
var point_5 = new OpenLayers.Geometry.Point(263, 202);
var point_5_Feature = new OpenLayers.Feature.Vector(point_5);
point_5_Feature.attributes = {
importance: 5
/* Layer Constructor */
/* In order to display the map, you must set a center and zoom
level. In order to zoom to fit the map into the window, you can use the
zoomToMaxExtent function, which will zoom as close as possible while still
fitting the full extents within the window. */
map.addLayers([basicMapLayer, monuments]);
map.zoomToMaxExtent();
// features for layer with cluster strategy must me declared after
layer is added in order to work
var monumentsFeature = new OpenLayers.Feature.Vector(
new
OpenLayers.Geometry.MultiPoint([point_1, point_2, point_3, point_4,
point_5])
monuments.addFeatures([point_1_Feature, point_2_Feature,
point_3_Feature, point_4_Feature, point_5_Feature]);
// end of init function
</script>
</head>
<body onLoad="init()">
<div style="width:100%; height:100%; border:#000 1px solid;
background:#000000;" id="map"></div>
</body>
</html>
-----Original Message-----
Sent: Thursday, February 17, 2011 4:29 AM
To: Misu Visan
Cc: OpenLayers User list
Subject: Re: [OpenLayers-Users] cluster strategy
There was a syntax error, replace the inner if with this:
>> On Wed, Feb 16, 2011 at 5:21 PM, Paul Spencer <pagameba at gmail.com> wrote:
>> change it to be
>> On 2011-02-16, at 9:54 AM, Mihai Visan wrote:
>>> Hi Paul,
>>> From: Paul Spencer
>>> Sent: Wednesday, February 16, 2011 3:37 PM
>>> To: Mihai Visan
>>> I don't know your code but I would assume that you are looking for
>>> something like this:
>>> var map = new OpenLayers.Map('mapDiv', mapOptions);
>>> var clusterStrategy = new OpenLayers.Strategy.Cluster(clusterOptions);
>>> var layerOptions = {
>>> var vectorLayers = new OpenLayers.Layer.Vector('features',
>>> layerOptions);
>>> var clusterMaxZoom = 10;
>>> map.events.register('move', null, function() { // #2, #3 respond to map
>>> extent change
>>> if (map.getZoom() > clusterMaxZoom) { // #2.1 how to read current zoom
>>> clusterStrategy.deactivate(); // #2.2 how to disable cluster
>>> strategy
>>> } else {
>>> var extent = map.getExtent(); // #3.1
>>> now
>>> BBOX strategy will have no effect and you will have to manually reload
>>> features using whatever mechanism you are using now.
>>> Cheers
>>> Paul
>>> On 2011-02-16, at 7:58 AM, Mihai Visan wrote:
>>>> Thanks Paul,
>>>> I already read the documentation and all tutorial and user discusions I
>>>> could found.
>>>> But I'm a week at javascript, so I could use some examples or tutorials
>>>> I could transform
>>>> -----Original Message----- From: Paul Spencer
>>>> Sent: Wednesday, February 16, 2011 2:43 PM
>>>> To: Mihai Visan
>>>> Mihai, all of your questions have answers in the documentation ...
>>>> On 2011-02-16, at 7:29 AM, Mihai Visan wrote:
>>>>> 2. disable cluster strategy at certain zoom level.
>>>>> Problems: 2.1. I don’t know how to read current zoom
>>>> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.getZoom
>>>>> 2.2. I don’t know to disable cluster strategy
>>>> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Strategy/Cluster-js.html#OpenLayers.Strategy.Cluster.deactivate
>>>>> 3. use (BBOX strategy and) ajax to disable features outside visible
>>>>> bounds
>>>>> Problems: 3.1. I don’t know how to read visible bounds
>>>> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.getExtent
>>>>> 3.2. I don’t know how to integrate ajax with
>>>>> (BBOX and) mouse drag or zoom in/out
>>>> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.EVENT_TYPES
>>>> Cheers
>>>> Paul
