[OpenLayers-Users] Re: Controll the Layervisibility by code
Slawomir Messner
slawomir.messner at staff.uni-marburg.de
Fri Feb 18 04:53:05 EST 2011
http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.getLayersByName
var layers = Map.getLayersByName(name);
if(layers.length > 0) {
layers[0].setVisiblity(true);
layers[i].redraw();
if you are sure name is unique or
for(var i = 0; i <layers.length > 0 ;i++){
layers[i].setVisiblity(true);
layers[i].redraw();
Am 18.02.2011 10:47, schrieb Jan Tappenbeck:
> Am 18.02.2011 10:09, schrieb Dominik Mikiewicz:
>> Map.layers[i].setVisibility(true);
>> Map.layers[i].redraw();
> hi !
> but i search an alternative-way so set the visibilty to the layer by
> the name - not the index i ?!?!??!
> regards Jan :-)
>> -----Original Message-----
>> From: openlayers-users-bounces at lists.osgeo.org
>> [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Jan
>> Tappenbeck
>> Sent: Friday, February 18, 2011 8:42 AM
>> To: users at openlayers.org
>> Subject: [OpenLayers-Users] Controll the Layervisibility by code
>> hi !
>> it is possible to define the visibility of a layer in the moment of
>> definition like
>> map.addLayer(new OpenLayers.Layer.OSM.Toolserver('osm-labels-en',
>> {isBaseLayer: false, visibility: true}));
>> but is it possible to control the visibility to a later time by code ??
>> i found following example:
>> for(var i=0;i<map.layers.length;i++)
>> { Msg += map.layers[i].name + " :: " + map.layers[i].visibility +
>> "\r\n";
>> but how to define the status exactly to a layer-variable-name? [i] is
>> not a
>> name ?!?!?
>> regards Jan :-)
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
