AW: [OpenLayers-Users] Re: Points on google layer
Phil Scadden
p.scadden at gns.cri.nz
Sun Feb 20 15:20:23 EST 2011
I am done with marking points(lat long values present in text file) on
> map correctly, Now I want to know whether there is a way to read radius
> values from .txt file and create circle around these markers,if yes how to
> do this?, or should I change my input file format,if yes, to which format
> should I change?
This is done with attribute-based styling but I dont know if text file
layers support attributes. Another good reason to put you data into a
proper spatial format (one of many). You can see how SLD is set up by
looking at point attribute styling in the SLD recipe book.
http://docs.geoserver.org/stable/en/user/styling/sld-cookbook/points.html#attribute-based-point
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
