[OpenLayers-Users] Re: Custom Layer From Non Standard Map Server
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Tue Jul 5 09:34:34 EDT 2011
singleTile is exactly what you want. It just means 1 tile per layer at a
time.
If implemented well, it will update on every map zoom and pan.
Best regards,
Bart
> Hi.
> Thank You
>> If you only need singleTile and not a gridded layer
> This is based on single image but when I pan/drag/zoom the map and release
> the mouse I would like to send another request to this server with actual
> bounds of the OpenLayers map.
> So this is not based on one singleTile but many images. Does Layer.WMS
> support this kind of requests (at the end of dragging/panning/zooming the
> map).
> http://osgeo-org.1803224.n2.nabble.com/Custom-Layer-From-Non-Standard-Map-Server-tp6549456p6549493.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
