AW: [OpenLayers-Users] Changing style based on feature attributes.
Arnd Wippermann
arnd.wippermann at web.de
Fri Jul 8 06:16:20 EDT 2011
Looking at the OpenLayers code I would overwrite getNodeType
OpenLayers.Renderer.SVG.prototype.getNodeType = function(geometry, style) {
var nodeType = null;
switch (geometry.CLASS_NAME) {
case "OpenLayers.Geometry.Point":
if (style.externalGraphic && style.externalGraphic!="") {
nodeType = "image";
} else if (this.isComplexSymbol(style.graphicName)) {
nodeType = this.supportUse === false ? "svg" : "use";
} else {
nodeType = "circle";
break;
case "OpenLayers.Geometry.Rectangle":
nodeType = "rect";
break;
case "OpenLayers.Geometry.LineString":
nodeType = "polyline";
break;
case "OpenLayers.Geometry.LinearRing":
nodeType = "polygon";
break;
case "OpenLayers.Geometry.Polygon":
case "OpenLayers.Geometry.Curve":
case "OpenLayers.Geometry.Surface":
nodeType = "path";
break;
default:
break;
return nodeType;
Similiar for VML.
What's your solution?
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von emmexx
Gesendet: Freitag, 8. Juli 2011 11:30
An: kapuch
Cc: users at openlayers.org
Betreff: Re: AW: [OpenLayers-Users] Changing style based on feature
attributes.
Il 07/08/2011 10:16 AM, kapuch scrisse:
> Try this and you will see that this is not the way to do this.
I sent a working example to your address.
To the developers: if the example can be of any help to others can we put it
in the examples folder or in the wiki?
thank you
maxx
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
