[OpenLayers-Users] Click Handler callback invoked 3 times
Dave Potts
dave.potts at pinan.co.uk
Sun Jul 10 04:13:58 EDT 2011
Using openlayers 2.10 I have installed a click
handler(Openlayers.Handler.Click) on a map , using a scale as the
control argument and the register function to install the callback as
type click.
When ever I do a single click, the call back routine gets called 3
times, is there any reason for this? I had assume it would only be
called once.
The same things happens with the double click callback!
I have checked and the callback is only installed once.
As side issue what is the best 'control' to use with this type handler?
I choose scale because it seemed other than writing a scale it did seem
do anything else(some of the other controls define callbacks)
