AW: [OpenLayers-Users] Design suggestions for Interactive map!
Robert Buckley
robertdbuckley at yahoo.com
Tue Jul 12 14:52:18 EDT 2011
Thanks for the geoMoose suggestion. Has anyone actually used it or is able to
show any other examples apart from the one demo project on the website?
cheers,
Rob
Von: Brent Fraser <bfraser at geoanalytic.com>
An: Robert Buckley <robertdbuckley at yahoo.com>
CC: users at openlayers.org
Gesendet: Dienstag, den 12. Juli 2011, 16:24:34 Uhr
Betreff: Re: [OpenLayers-Users] Design suggestions for Interactive map!
Rob,
GeoMoose (http://www.geomoose.org/) is an OpenLayers based project that
supplies a complete (+/-) GUI, including a "Jump To" combobox and a tabbed
set of panels for displaying information. You may be able to get some ideas
from it...
Best Regards,
Brent Fraser
On 7/12/2011 7:07 AM, Robert Buckley wrote:
>I need some ideas on how to start a project using openlayers. The
>project entails a simple map which shows points. Each point has
>certain attributes (strings/integers)which correspond to locations in
>a town. My department would like a map which shows the individual
>attributes and the sum totals of the integer field listed in the
>attribute table beside the map when they are present in the map(ie
>BBOX strategy) or through a selection process(combo control?).
>eg. select town A from the comboBox -> the map zooms to the town
>bounds -> the statistics from the points present in that town are
>displayed in tabular form beside the map.
>Is this kind of thing do-able in an interactive way using postgis and
>geoserver, or should I be looked at static json lists?
>How /where should I start looking?
>If anyone has done similar work or has seen such maps i´d be grateful
>to see them,
>Yours,
>Rob
>_______________________________________________
>Users mailing list
>Users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110712/3f2b20f4/attachment.html
