[OpenLayers-Users] GPS coordinate (GPS from mobile devices),
lonlat and OpenLayers.Icon
Noli Sicad
nsicad at gmail.com
Wed Jul 13 09:35:46 EDT 2011
Thanks for the tip.
However, I rather do the GPS, since this is native app (hybrid app -
Xcode and JS) and use
position.coords.latitude
position.coords.longitude
See the advantage here:
http://www.thecssninja.com/javascript/geolocation-iphone
Noli
On 7/13/11, Nicholas Efremov-Kendall <n.e.kendall at gmail.com> wrote:
> set : enablehighaccuracy to True, that actually access the GPS on the
> devices.
> On Wed, Jul 13, 2011 at 1:02 AM, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi,
>> I would like to replace the Geolocate control functionality to reading
>> from the GPS from mobile devices (e.g. iPhone and iPad 2). Geolocate
>> html5 is so off from the actual real coordinate (lonLat) like 500
>> metres away.
>> How are do I am going to do this in easiest and nicer way?
>> I am able to get the my current location (i.e. lon and lat values)
>> from the iPhone/ iPad GPS to HTML DOM (i.e. Textbox).
>> e.g.
>> jQTouch with Xcode,
>> <ul class="edit rounded">
>> <li>Longitude: <input id='lng' type="text" value='' /></li>
>> <li>Latitude: <input id='lat' type="text" value='' /></li>
>> </ul>
>> Now, the question is, would I be able to get icon from the local
>> directory, not from http server?
>> In this example below, it seems that OpenLayers.Icon is retrieved from
>> http server.
>> var icon = new OpenLayers.Icon('
>> http://www.openstreetmap.org/openlayers/img/marker.png',size,offset);
>> layerMarkers.addMarker(new OpenLayers.Marker(lonLat,icon));
>> from, http://wiki.openstreetmap.org/wiki/Openlayers_Track_example
>> If not, would vector maker good option for this?
>> In this example, http://openlayers.org/dev/examples/geolocation.html
>> How can I mapulated this function to cater to the lon and lat values
>> from the GPS?
>> var geolocate = new OpenLayers.Control.Geolocate({
>> bind: false,
>> geolocationOptions: {
>> enableHighAccuracy: false,
>> maximumAge: 0,
>> timeout: 7000
>> map.addControl(geolocate);
>> var firstGeolocation = true;
>> geolocate.events.register("locationupdated",geolocate,function(e) {
>> vector.removeAllFeatures();
>> var circle = new OpenLayers.Feature.Vector(
>> OpenLayers.Geometry.Polygon.createRegularPolygon(
>> new OpenLayers.Geometry.Point(e.point.x, e.point.y),
>> e.position.coords.accuracy/2,
>> 40,
>> 0
>> style
>> vector.addFeatures([
>> e.point,
>> graphicName: 'cross',
>> strokeColor: '#f00',
>> strokeWidth: 2,
>> fillOpacity: 0,
>> pointRadius: 10
>> circle
>> if (firstGeolocation) {
>> map.zoomToExtent(vector.getDataExtent());
>> pulsate(circle);
>> firstGeolocation = false;
>> this.bind = true;
>> geolocate.events.register("locationfailed",this,function() {
>> OpenLayers.Console.log('Location detection failed');
>> Any ideas and implementation how to do this?
>> Thanks.
>> Regards, Noli
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
