[OpenLayers-Users] saving a state of a map
Michael
mdm at yachtpc.com
Sat Jul 16 01:26:34 EDT 2011
I think offering both is clever, and maybe you can use some of the same
code!
On 7/15/2011 11:09 AM, Greg Allensworth wrote:
> On 7/15/2011 11:03 AM, Huey Brantley wrote:
>> Permalink would create a url to that view. You would also extend the
>> Bookmark control to save the position to a cookie.
> True, the Permalink and ArgParser are a good route to do this too.
> Depends on your use case.
> Permalink has the advantage that SOMEONE ELSE can visit that big long
> URL and see the same map as yourself. It means more work for the users
> (copy and pasting URLs) but does give the ability to share your map
> with someone else. You can't do that with cookies.
> The cookie method has the advantage of not requiring the user to copy
> and paste a long URL: you visit the same map as always, and ta-da it's
> the same as before. This is great when the user may be visiting all
> over the website and you want state retained, and passing around a big
> long URL may not be feasible.
