AW: [OpenLayers-Users] Call a SLD file for a Vector Layer
Arnd Wippermann arnd.wippermann at web.de
Mon Jul 18 12:17:07 EDT 2011
As far as I know you can't load data with OpenLayers.Format.SLD(url). You
have to do it with an ajax call, i.e LoadUrl.
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von gbrun
Gesendet: Montag, 18. Juli 2011 12:32
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] Call a SLD file for a Vector Layer
Hi list!
I would like to apply SLD styles to my vector layers. It should work like in
this example : http://www.openlayers.org/dev/examples/sld.html
But what I want to do is a little bit different: each layer has its own
style. So I want that each vector layer calls its default style from a
folder in my web application where styles are stored with the same name as
their specific layer. For example, my application has a vector layer named
"vector". In this case, this layer must called a SLD file named
"vector.xml".
The OpenLayers example uses a "OpenLayers.LoadURL()" method. I'm looking for
a different way: I would like to read the SLD response without this method.
It should look like this:
var url_sld = "../sld/"+featureType.name+".xml";
			var format_sld = new OpenLayers.Format.SLD(url_sld);
			processResponse : function (response){
				var sld =
format_sld.read(response.responseXML ||
response.responseText);
But it doesn't work. I think, there is something that I don't understand
when I read the SLD response.
Can someone clarify me this?
Geoffrey
Using Opera's revolutionary email client: http://www.opera.com/mail/
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
