[OpenLayers-Users] Google maps layer with SVG overlay
jc9121 jamescauchi at gmail.com
Fri Jul 22 01:14:48 EDT 2011
Dear OpenLayers community,
I have an OpenLayers map with the following layers in the layer switcher:
Google Physical
Google Streets
Google Hybrid
Google Satellite
Open Street Map
I would like to add a dynamically generated SVG overlay.
The SVG will be generated server side by PHP.
SVG will not be WMS it will be generated by php based on the bounding box of
the current map view.
I was looking at the Xhtml addin because i need the SVG objects to respond
to mouse events.
I tried testing this using static SVG based on the examples from the
inlineXhtml addin however I was unable to successfully display any SVG over
the existing map layers.
I was looking at this example:
http://dev.openlayers.org/addins/InlineXhtml/trunk/examples/example3.htm
However this has a scalable layer with fixed bounds.
Since my layer will be generated dynamically based on the Bounding Box of
the current map view it doesn't have fixed bounds and does not need to be
scalable.
Can anyone point me to an example of this?
Thank you
br
James
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Google-maps-layer-with-SVG-overlay-tp6609380p6609380.html
