[OpenLayers-Users] Re: WMS over Google Maps when panning tiles not
in synch
Alessandro Ferrucci
alessandroferrucci at gmail.com
Sun Jul 24 15:56:24 EDT 2011
I am experiencing the exact same of what this ticket says:
http://trac.osgeo.org/openlayers/ticket/2929
does this mean that currently it's an issue in google maps v3?
Thanks,
Alessandro Ferrucci
On Sun, Jul 24, 2011 at 3:50 PM, Alessandro Ferrucci
<alessandroferrucci at gmail.com> wrote:
> Hello,
> I have the following code
> var map;
> var projectionWGS84 = new OpenLayers.Projection("EPSG:4326");
> var projectionMercator = new OpenLayers.Projection("EPSG:900913");
> // Avoid pink error tiles
> OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
> OpenLayers.Util.onImageLoadErrorColor = "transparent";
> function init(){
> var options = {
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> units: "m",
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-20037508,
> -20037508,20037508, 20037508),
> restrictedExtent: new
> OpenLayers.Bounds(-164.88281,5.09094,-41.39648,52.69636).transform(projectionWGS84,projectionMercator),
> controls:[
> new OpenLayers.Control.Navigation(),
> new OpenLayers.Control.ArgParser(),
> new OpenLayers.Control.Attribution(),
> new OpenLayers.Control.PanZoomBar({ position:
> new OpenLayers.Pixel(2, 15) }),
> new OpenLayers.Control.Scale($('scale')),
> new OpenLayers.Control.LayerSwitcher(),
> new OpenLayers.Control.MousePosition(),
> new OpenLayers.Control.Permalink()
> map = new OpenLayers.Map('map',options);
> var googleHibridLayer = new OpenLayers.Layer.Google(
> "Google Hibrid", {type: google.maps.MapTypeId.HYBRID,
> 'sphericalMercator': true,isBaseLayer: true } );
> var googleStreetLayer = new OpenLayers.Layer.Google(
> "Google Street", {'sphericalMercator':true} );
> var addressLayer = new OpenLayers.Layer.WMS(
> "Addresses", "<WMS SERVER HOSTNAME>",
> LAYERS: 'cira:address',
> STYLES: '',
> format: 'image/png',
> tiled: true,
> transparent:true,
> tilesOrigin : map.maxExtent.left + ',' +
> map.maxExtent.bottom
> buffer: 10,
> displayOutsideMaxExtent: true,
> isBaseLayer: false
> map.addLayers([googleStreetLayer,googleHibridLayer,addressLayer]);
> var USABounds=new
> OpenLayers.Bounds(-124.731,24.956,-66.97,49.372);
> USABounds.transform(projectionWGS84,map.getProjectionObject());
> map.zoomToExtent(USABounds);
> The WMS looks to be overlaying fine, but when I pan the map the tiles
> look like they are "shifting plates" meaning they look like they are
> moving independently and it looks quite ugly.
> I have tried adding "projection: new
> OpenLayers.Projection("EPSG:900913")," as an option to the WMS layer
> itself thinking maybe that would fix it but it did not.
> I'm using stable Openlayers 2.10
> Any ideas?
> Thank you,
> Signed,
> Alessandro Ferrucci
Signed,
Alessandro Ferrucci
