[OpenLayers-Users] WMS URL - BBOX projection half-right...
Christophe Noel
Christophe.Noel at spacebel.be
Mon Jun 6 11:40:32 EDT 2011
Hello all,
I'm using OpenLayers 2.10 for a while, but I cannot understand the following issue: when I add a WMS (projection EPSG:31370) to the map (baselayer is also EPSG:31370), the BBOX used projection of the generated URL is half right/wrong.
WMS URL : http://172.17.5.4/cgi-bin/mapserv?map=/usr/lib/cgi-bin/MS/3WSA/2011-06-06_u2Mrj_mapfilesld.map
Generated URL : http://172.17.5.4/cgi-bin/mapserv?map=/usr/lib/cgi-bin/MS/3WSA/2011-06-06_u2Mrj_mapfilesld.map&LAYERS=so2&EXCEPTIONS=XML&FORMAT=image%2Fpng&TRANSPARENT=TRUE&VERSION=1.1.0&SERVICE=WMS&REQUEST=GetMap&STYLES=&SRS=EPSG%3A31370&BBOX=-180,-90,79820,79910&WIDTH=256&HEIGHT=256
As you see, some parameters of the BBOX are -180,-90 which are not correct and in EPSG:4326 instead of EPSG:31370.
Anybody can help ?
Thanks very much.
Christophe NOEL.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110606/cbcfeacf/attachment.html
