[OpenLayers-Users] Re: How to add tooltip to marker?
sherin
angelsherin24 at gmail.com
Mon Jun 6 18:51:16 EDT 2011
ADD the following code to your javscript:
OpenLayers.Marker.Label = OpenLayers.Class(OpenLayers.Marker, {
* Property: labelDiv
* {DOMElement}
labelDiv: null,
* Property: label
* {String}
label: null,
* Property: label
* {Boolean}
mouseOver: false,
* Property: labelClass
* {String}
labelClass: "olMarkerLabel",
* Property: events
* {<OpenLayers.Events>} the event handler.
events: null,
* Property: div
* {DOMElement}
div: null,
* Property: onlyOnMouseOver
* {Boolean}
onlyOnMouseOver: false,
* Property: mouseover
* {Boolean}
mouseover: false,
* Property: labelOffset
* {String}
labelOffset: "10px",
* Constructor: OpenLayers.Marker.Label
* Parameters:
* icon - {<OpenLayers.Icon>} the icon for this marker
* lonlat - {<OpenLayers.LonLat>} the position of this marker
* label - {String} the position of this marker
* options - {Object}
initialize: function(lonlat, icon, label, options) {
var newArguments = [];
OpenLayers.Util.extend(this, options);
newArguments.push(lonlat, icon, label);
OpenLayers.Marker.prototype.initialize.apply(this, newArguments);
this.label = label;
this.labelDiv = OpenLayers.Util.createDiv(this.icon.id + "_Text",
null, null);
this.labelDiv.className = this.labelClass;
this.labelDiv.innerHTML = label;
this.labelDiv.style.marginTop = this.labelOffset;
this.labelDiv.style.marginLeft = this.labelOffset;
* APIMethod: destroy
* Destroy the marker. You must first remove the marker from any
* layer which it has been added to, or you will get buggy behavior.
* (This can not be done within the marker since the marker does not
* know which layer it is attached to.)
destroy: function() {
this.label = null;
this.labelDiv = null;
OpenLayers.Marker.prototype.destroy.apply(this, arguments);
* Method: draw
* Calls draw on the icon, and returns that output.
* Parameters:
* px - {<OpenLayers.Pixel>}
* Returns:
* {DOMElement} A new DOM Image with this marker's icon set at the
* location passed-in
draw: function(px) {
this.div = OpenLayers.Marker.prototype.draw.apply(this, arguments);
this.div.appendChild(this.labelDiv, this.div.firstChild);
if (this.mouseOver === true) {
this.setLabelVisibility(false);
this.events.register("mouseover", this, this.onmouseover);
this.events.register("mouseout", this, this.onmouseout);
else {
this.setLabelVisibility(true);
return this.div;
* Method: onmouseover
* When mouse comes up within the popup, after going down
* in it, reset the flag, and then (once again) do not
* propagate the event, but do so safely so that user can
* select text inside
* Parameters:
* evt - {Event}
onmouseover: function (evt) {
if (!this.mouseover) {
this.mouseover = true;
if (this.map.getSize().w -
this.map.getPixelFromLonLat(this.lonlat).x<50) {
this.labelDiv.style.marginLeft = (-10-this.icon.size.w)+"px";
if (this.map.getSize().h -
this.map.getPixelFromLonLat(this.lonlat).y<50) {
this.labelDiv.style.marginTop = (-10-this.icon.size.h)+"px";
OpenLayers.Event.stop(evt, true);
* Method: onmouseout
* When mouse goes out of the popup set the flag to false so that
* if they let go and then drag back in, we won't be confused.
* Parameters:
* evt - {Event}
onmouseout: function (evt) {
this.mouseover = false;
* Method: setLabel
* Set new label
* Parameters:
* label - {String}
setLabel: function (label) {
this.label=label;
* Method: setLabelVisibility
* Toggle label visibility
* Parameters:
* visibility - {Boolean}
setLabelVisibility: function (visibility) {
if (visibility) {
this.labelDiv.style.display = "block";
else {
this.labelDiv.style.display = "none";
* Method: getLabelVisibility
* Get label visibility
* Returns:
getLabelVisibility: function () {
if (this.labelDiv.style == "none") {
return false;
else {
return true;
CLASS_NAME: "OpenLayers.Marker.Label"
AND...
Instead of markers.addMArker -->
markers.addMarker(new OpenLayers.Marker.Label(point, icon.clone(), 'Tool
Tip Text ' ,{mouseOver:true}));
Also add this to your stylesheet:
.olMarkerLabel {
font-size: small;
color: black;
background-color: #FFFFCC;
width: auto;
padding: 1px;
border: 1px black solid;
z-index: 1000;
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-add-tooltip-to-marker-tp6445775p6447312.html
