[OpenLayers-Users] enabling popup with attribute information on
multiple vector layers
Vishal Mehta
vishalm1975 at gmail.com
Mon Jun 6 19:21:58 EDT 2011
Hello all,
For starters, I would like to put up a number of vector layers (points and
polygons) on an OL application. For now there are 2 vector layers in kml
format on my server.
Here's the link:
http://99.35.104.33/bangalore/bangalore_osm_kml_popup3.html
And the script is at bottom.
My qn is: how do i make a generic SelectFeatureEvent and popUp functions
(like the one i have below for borewells vector layer) such that one set of
functions will apply to any and all layers? As of now. given my very limited
javascript experience, I only know that I could develop one set of
functions for every single layer, which seems inefficient.
FYI, each vector layer has different number and attribute titles. Is it
possible maybe to refer to an atttribute column number instead of the
attribute title?.
BTW, if there is an informal OL users meetup or support group in the
Davis/Sacramento area please let me know. I'm trying to develop something
quite interactive and complex (to me, in terms of web programming) and could
use some help over time...
Thanks,
Vishal
<html>
<head>
<title>OpenLayers Example</title>
<!--script src="http://openlayers.org/api/OpenLayers.js
"></script-->
<script src='javascript/OpenLayers-2.10/OpenLayers.js'></script>
<link rel='stylesheet' href='css/trystyle.css' />
</head>
<body>
<div id="toppage">
<h1> this is the top page </h1>
</div>
<div id="rightpage">
<h1> this is the right page </h1>
<p>
<form method="POST" action="bangalore3.php">
<input type="radio" name="action" value="All" /> All<br />
<input type="radio" name="action" value="Average" /> Average
<input type="submit" value="Submit" />
</form>
</p>
</div>
<div id="map">
<script defer="defer" type="text/javascript">
// pink tile avoidance
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;
// make OL compute scale according to WMS spec
OpenLayers.DOTS_PER_INCH = 25.4 / 0.28;
var map = new OpenLayers.Map(
'map',
{displayProjection: new OpenLayers.Projection("EPSG:4326")}
var bounds = new OpenLayers.Bounds(
77.541, 12.935,
77.626, 13.000
var osm = new OpenLayers.Layer.OSM(
"Simple OSM Map")
//console.log(map.getProjection());
map.addLayer(osm);
map.setCenter(
new OpenLayers.LonLat(77.6,13).transform(
new OpenLayers.Projection("EPSG:4326"),
map.getProjectionObject()
), 13);
var borewells = new OpenLayers.Layer.Vector('borewells',
projection: new OpenLayers.Projection('EPSG:4326'),
protocol: new OpenLayers.Protocol.HTTP({
url: "borewells.kml",
format: new OpenLayers.Format.KML({
extractAttributes: true,
extractStyles: true
visibility: true,
strategies: [new OpenLayers.Strategy.Fixed()]
var wards = new OpenLayers.Layer.Vector('wards',
url: "Wards27.kml",
extractStyles: true
visibility: false,
//add it to the map
map.addLayers([borewells,wards]);
// Add a layer switcher control and mouse poistion control
map.addControls(
[new OpenLayers.Control.LayerSwitcher({}),
new OpenLayers.Control.MousePosition({})]
//create a variable for the SelectFeature Control
selectborewells = new OpenLayers.Control.SelectFeature(borewells);
selectwards = new OpenLayers.Control.SelectFeature(wards);//not
implemented yet
// 2 functions will be called when select and unselect events are fired
borewells.events.on({
"featureselected": onFeatureSelect,
"featureunselected": onFeatureUnselect
//add the control to the map
map.addControl(selectborewells);
//activate it
selectborewells.activate();
//not sure what evt is
function onPopupClose(evt) {
selectborewells.unselectAll();
// this function for what happens when selecting a feature
// not sure exactly whats happening
function onFeatureSelect(event) {
var feature = event.feature;
// Since KML is user-generated, do naive protection against
// Javascript.
//var content = feature.attributes;
var content = "<h3> Water Depth
(metres)</h3>"+feature.attributes.Code_No.value + "</br>" +
feature.attributes.Water_Leve.value.substr(0,4);
if (content.search("<script") != -1) {
content = "Content contained Javascript! Escaped content
below.<br />" + content.replace(/</g, "<");
popup = new OpenLayers.Popup.FramedCloud("chicken",
feature.geometry.getBounds().getCenterLonLat(),
new OpenLayers.Size(100,100),
content,
null, true, onPopupClose);
feature.popup = popup;
map.addPopup(popup);
// this function for when unselected
function onFeatureUnselect(event) {
if(feature.popup) {
map.removePopup(feature.popup);
feature.popup.destroy();
delete feature.popup;
</script>
</div>
</body>
</html>
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110606/98e321c7/attachment-0001.html
