[OpenLayers-Users] Re: Automatic updation of OpenLayers code
Robert Sanson
Robert.Sanson at asurequality.com
Wed Jun 8 00:46:09 EDT 2011
I also do the same using Mapserver, so it should be possible with Geoserver. In my case, I use ColdFusion to put the user-entered data into a SQL db, and then update the layer, which destroys it and then reloads it from Mapserver.
Robert
>>> Vikash Talanki <vikashtalanki at gmail.com> 8/06/2011 4:43 p.m. >>>
Yes Robert I think I should give it a try. I am also trying to do the same
thing using geoserver, after storing the values in db , I have to manually
publish the layer in geoserver and add its code in JS, Is there a way to do
this programmatically??.... like running the geoserver and adding a layer by
calling a function etc
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Automatic-updation-of-OpenLayers-code-tp6452157p6452335.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110608/af0f1528/attachment-0001.html
