[OpenLayers-Users] Re: Problems getting WFS layer
Casper Span
info at spatially-oriented.com
Thu Jun 9 06:05:50 EDT 2011
A small followup... I've found out a few things in the meantime. For
starters, I had a missing proxy. I've added this into apache now, so it
forwards everything nicely from port 80 to port 8080 to geoserver.
My layer had a few changes as well:
wfs = new OpenLayers.Layer.Vector("Editable Features", {
strategies: [new OpenLayers.Strategy.BBOX()],
projection: new OpenLayers.Projection("EPSG:28992"),
protocol: new OpenLayers.Protocol.WFS({
version: "1.1.0",
srsName: "EPSG:28992",
url: "http://casp-geoserver/geoserver/wfs",
featureNS : "http://casp-geoserver/",
featureType: "locatiedossiers",
geometryName: "geometry",
schema: "
http://casp-geoserver/geoserver/wfs/DescribeFeatureType?version=1.1.0&typename=gs:locatiedossiers
This is basically just the WFS Transactional sample from OL, with my server
adres and layer in it. I have doublechecked all the url's, namespaces, etc.
I really don't know what to check next. Firebug tries to get something from
WFS "OPTIONS wfs", but the reponse is empty. That's the only WFS related
line on the NET tab in FireBug.
I can serve the layer through WMS without any problems. The WMS is also
served through the proxy, so that should work properly.
I'm currently using GeoServer 2.1 RC2, OL 2.10. This problem is the same for
Firefox 4, Chrome 12 and IE8.
I really hope I'm missing just a small thing, because I've been at this
problem for a few days already...
Regards,
Casper Span
On Thu, May 26, 2011 at 11:22 AM, Casper Span
<info at spatially-oriented.com>wrote:
> Hi list,
> I know this question has been asked before (many times I guess), but
> somehow I just can't get this thing to work. Unfortunately, Google isn't my
> friend either.
> So, I have this setup:
> - Oracle Spatial database
> - Geoserver serving WFS and WMS and setup with a single layer
> - OpenLayers
> So nothing fancy there.
> I created a layer using the samples and docs. It came down to this:
> var locdos = new OpenLayers.Layer.Vector("Locatiedossiers", {
> version: "1.1.0",
> url: "http://roxit-geoserver:8080/geoserver/wfs",
> featureType: "Locatiedossiers",
> geometryName: "GEOMETRIE",
> featureNS: "http://www.roxit.nl",
> schema: "
> http://roxit-geoserver:8080/geoserver/wfs/DescribeFeatureType?version=1.1.0&featuretype=Locatiedossiers
> So I added that to my map and booted firefox. Nothing is being loaded.
> Looking at firebug: OL does a request to /wfs and gets an empty response.
> The geoserver setup works like a charm when I use it with, for example uDig
> and Gaia.
> I've tried adding the prefix with the featureType, but removed that after
> reading a post from Bart vd Eijnden saying it should be removed.
> I'm most likely missing something trivial, but I just can't find it. Any
> suggestions?
> Regards,
> Casper Span
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110609/ddaafa56/attachment.html
