[OpenLayers-Users] Re: Problems getting WFS layer
Casper Span
info at spatially-oriented.com
Thu Jun 9 11:21:14 EDT 2011
Bart,
Thanks for the response again, the BBOX seemed to be wrong indeed. There is
something with the google baselayers that mess up everything. I now have it
working with only my own data!
I also found out another strange thing: my WFS isn't working if I go to the
site by:
http://localhost/openlayers/index.php
but I CAN see the WFS through:
http://casp-geoserver/openlayers/index.php
Is that another problem with the http security? perhaps because of the hosts
file redirecting localhost to 127.0.0.1?
Anyway, I finally have WFS loaded now! thanks a lot!
Regards,
Casper
On Thu, Jun 9, 2011 at 4:18 PM, Bart van den Eijnden <bartvde at osgis.nl>wrote:
> Hi Casper,
> that does not look like a valid BBOX to me in RD (EPSG:28992). Such no data
> is coming back.
> displayProjection is used by e.g. the MousePosition control, it will
> display the X and Y in a different projection than the map is in.
> What you want is to set projection to EPSG:28992.
> If you can't figure out the correct map settings for RD, have a look at
> some existing application in RD such as:
> http://www.rijkswaterstaat.nl/apps/geoservices/mapviewer2i/
> or:
> https://www.kademo.nl/
> Hope this helps.
> Best regards,
> Bart
> Looking for flexible support on OpenLayers or GeoExt? Please check out
> http://www.osgis.nl/support.html
> OSGIS
> bartvde at osgis.nl
> On Jun 9, 2011, at 4:12 PM, Casper Span wrote:
> Hi Bart, Mark,
> There is nothing related to WFS on the console, nor on NET's XHR subtab.
> Even when everything is checked. It's like it crashes before it gets
> there... (with no error, ofcourse...) I've also tried your suggestion, Mark.
> Still the same.
> The DescribeFeatureType:
> <?xml version="1.0" encoding="UTF-8"?>
> <xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:gml="
> http://www.opengis.net/gml" xmlns:gs="http://casp-geoserver/"
> elementFormDefault="qualified" targetNamespace="http://casp-geoserver/">
> <xsd:import namespace="http://www.opengis.net/gml" schemaLocation="
> http://localhost:80/geoserver/schemas/gml/3.1.1/base/gml.xsd"/>
> <xsd:complexType name="locatiedossiersType">
> <xsd:complexContent>
> <xsd:extension base="gml:AbstractFeatureType">
> <xsd:sequence>
> <xsd:element maxOccurs="1" minOccurs="0" name="ID"
> nillable="true" type="xsd:decimal"/>
> <xsd:element maxOccurs="1" minOccurs="0" name="GEOMETRY"
> nillable="true" type="gml:GeometryPropertyType"/>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexContent>
> </xsd:complexType>
> <xsd:element name="locatiedossiers" substitutionGroup="gml:_Feature"
> type="gs:locatiedossiersType"/>
> </xsd:schema>
> Hmm... I just tried another request from a different pc... now I suddenly
> DID get some xhhtp on the NET panel:
> REQUEST:
> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
> version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://casp-geoserver/
> http://casp-geoserver/geoserver/wfs/DescribeFeatureType?version=1.1.0&typename=gs:locatiedossiers
> " xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <wfs:Query typeName="feature:locatiedossiers" srsName="EPSG:28992"
> xmlns:feature="http://casp-geoserver/">
> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
> <ogc:BBOX>
> <ogc:PropertyName>GEOMETRY</ogc:PropertyName>
> <gml:Envelope xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:28992">
> <gml:lowerCorner>562664.54279097 6811227.9320805</gml:lowerCorner>
> <gml:upperCorner>574130.09703169 6820515.0310153</gml:upperCorner>
> </gml:Envelope>
> </ogc:BBOX>
> </ogc:Filter>
> </wfs:Query>
> </wfs:GetFeature>
> RESPONSE:
> <wfs:FeatureCollection numberOfFeatures="0" timeStamp="
> 2011-06-09T16:09:36.265+02:00" xsi:schemaLocation="http://casp-geoserver/
> http://casp-geoserver:80/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=gs%3Alocatiedossiers
> http://casp-geoserver:80/geoserver/schemas/wfs/1.1.0/wfs.xsd" xmlns:gs="
> http://casp-geoserver/" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="
> http://www.opengis.net/gml" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="
> http://www.w3.org/1999/xlink" xmlns:ows="http://www.opengis.net/ows"
> xmlns:wfs="http://www.opengis.net/wfs">
> <gml:featureMembers></gml:featureMembers>
> </wfs:FeatureCollection>
> So basically, it can't find anything... Maybe this is a projection related
> issue then... The data is EPSG:28992,
> My Map options hash have:
> projection: new OpenLayers.Projection("EPSG:4326"),
> displayProjection: new OpenLayers.Projection("EPSG:28992"),
> Could there be a mixup there? I still find the projection/displayProjection
> really confusing... what's the real difference between the two?
> regards,
> Casper
> On Thu, Jun 9, 2011 at 2:33 PM, Mª®k <mc.prins at gmail.com> wrote:
>> 2011/6/9 Bart van den Eijnden <bartvde at osgis.nl>:
>> > Hi Casper,
>> > AJAX requests normally show up in the Console tab of Firebug, make you
>> sure
>> > you have activated the option to show AJAX requests.
>> > Without a request XML and response XML it's really difficult to help
>> you.
>> > Otherwise, send us the output of your DescribeFeatureType request, a
>> common
>> > mistake is that the featureNS does not exactly match the namespace
>> > advertized on the WFS.
>> my most common mistake here is a trailing slash on the namespace,
>> always gets me...
>> You might also want to try adding the featurePrefix : 'gs' to the
>> options hash (I see you're using that in the schema url).
>> Mark
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110609/6eece397/attachment-0001.html
