[OpenLayers-Users] Problems displaying points with rule
basedstyle [SOLVED]
David Alda Fernandez de Lezea
dalda at ikt.es
Fri Jun 10 06:20:08 EDT 2011
I think I've found something. I'm using my layer in order to show different kind of features (points, lines, polygons) loaded with an Ajax process and also I use it to save data through a WFS-T service. So, when I set a protocol and a strategy to the layer I get this confusing behaviour but if I don't set those properties, everything works fine.
I'll change some parts of the application's code to make it work.
Just to let you know.
Regards,
Un saludo,
David Alda Fernández de Lezea
Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
IKT
Granja Modelo s/n · 01192 · Arkaute (Araba)
Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
email: dalda at ikt.es web: www.ikt.es
-----Mensaje original-----
De: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] En nombre de David Alda Fernandez de Lezea
Enviado el: miércoles, 08 de junio de 2011 9:10
Para: users at openlayers.org
Asunto: RE: [OpenLayers-Users] Problems displaying points with rule basedstyle
I'm adding 500 points, I know they are a lot of points, but before modifying my layer style to use rules (a use a now a mapstyle), they were properly added, but now not.
What could be the difference?
Thanks.
Un saludo,
IKT
De: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] En nombre de David Alda Fernandez de Lezea Enviado el: martes, 31 de mayo de 2011 10:15
Sorry for the double posting, it was a mistake.
De: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] En nombre de David Alda Fernandez de Lezea Enviado el: martes, 31 de mayo de 2011 9:24
Asunto: RV: [OpenLayers-Users] Problems displaying points with rule basedstyle
Any ideas?
I think I'm using OpenLayers 2.9 and this behaviour is happening in IE8.
Un saludo,
IKT
De: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] En nombre de David Alda Fernandez de Lezea Enviado el: lunes, 11 de abril de 2011 13:27
Para: openlayers-users at lists.osgeo.org
Asunto: [OpenLayers-Users] Problems displaying points with rule based style
Hi list,
I'm trying to display some points in a Vector Layer that has a style map defined. My layer's style map is:
var styles = new OpenLayers.StyleMap({
"default": new OpenLayers.Style(null, {
rules: [
new OpenLayers.Rule({
symbolizer: {
"Point": {
pointRadius: 5,
graphicName: "circle",
fillColor: "#FFA500",
fillOpacity: 0.25,
strokeWidth: 1,
strokeOpacity: 1,
strokeColor: "#FFA500"
"Line": {
strokeWidth: 3,
strokeOpacity: 1,
"Polygon": {
strokeWidth: 2,
strokeOpacity: 1,
strokeColor: "#FFA500",
"select": new OpenLayers.Style({
strokeColor: "#00ccff",
strokeWidth: 4,
strokeDashstyle: "solid"
"temporary": new OpenLayers.Style(null, {
rules: [
symbolizer: {
"Point": {
pointRadius: 5,
graphicName: "square",
fillColor: "white",
fillOpacity: 0.25,
strokeWidth: 1,
strokeOpacity: 1,
strokeColor: "#333333"
"Line": {
strokeWidth: 3,
strokeOpacity: 1,
"Polygon": {
strokeWidth: 2,
strokeOpacity: 1,
strokeColor: "#0000ff",
fillColor: "#0000ff"
And I add my points doing:
var coords = pto.getCoords().split(",");
var pointStyle ={
pointRadius: pto.getGrosor(),
fillOpacity: 1,
strokeOpacity: 1,
strokeColor: "black",
label: pto.getLabelText(),
labelAlign: "rt",
strokeWidth: 1,
fillColor: "#" + pto.getColor(),
graphicName: pto.getTipo(),
fontColor: "#" + pto.getLabelColor(),
fontSize: pto.getLabelSize(),
fontWeight: "bold"
var feat = new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(coords[0],coords[1]));
feat.attributes["id"] = pto.getID();
feat.fid = "punto." + pto.getCoords();
feat.state = OpenLayers.State.INSERT;
//feat.renderIntent = "default";
var rule = new OpenLayers.Rule({
filter: new OpenLayers.Filter.Comparison({
type: OpenLayers.Filter.Comparison.EQUAL_TO,
property: "id",
value: pto.getID()
symbolizer: pointStyle
pila.styleMap.styles["default"].addRules([rule, new OpenLayers.Rule({elseFilter: true})]);
vectorLayer.addFeatures([feat]);
It's strange because they appear just for one second and suddenly they disappear from the layer!! Has anyone noticed something like this??
Thanks.
Regards,
Un saludo,
IKT
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
Users mailing list
Users mailing list
Users mailing list
