AW: [OpenLayers-Users] Re: help with removing/replacing a markerafter
click event
Arnd Wippermann
arnd.wippermann at web.de
Mon Jun 13 03:13:50 EDT 2011
if you use Feature.Vector markers to display your markers, try
if(vectorLayer.features.length>0)
vectorLayer.removeFeatures(vectorLayer.features);
to remove the marker before you add a marker at the new position.
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL210/Map_mit_Marker.asp
or use a DragFeature.Control to drag the marker around.
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL26/examples/gc_example.html
Or both.
i was not able to update the position of the marker by updating the geometry
and redraw the feature. The label moves to the new position, but the marker
(the externalGraphic) wouldn't move!?
Arnd
_____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Nicholas
Efremov-Kendall
Gesendet: Samstag, 11. Juni 2011 18:43
An: Rossko
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Re: help with removing/replacing a
markerafter click event
Hi Rosco,
No, I hadn't thought of that. Any suggestions on how to update the position
of the marker, maybe a loop with a new LonLat?
On Sat, Jun 11, 2011 at 5:00 AM, Rossko <rossko at culzean.clara.co.uk> wrote:
> The issue is that each time the user clicks, another marker is placed.
This
isn't really a problem, but for
> aesthetic purposes, I'd like to destroy or remove the first marker if the
> clicks again
Have you considered a different approach to coding this, create one marker
and move it around.
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/help-with-removing-replacing-a-marker
-after-click-event-tp6463400p6464936.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110613/f7c2f88b/attachment.html
