[OpenLayers-Users] Re: Vector Feature Clustering
Christian Ledermann
christian.ledermann at gmail.com
Thu Jun 16 10:37:52 EDT 2011
try: http://iwlearn.net/iw-projects
it is a not overcomplicated example of a clustered map
On Thu, Jun 16, 2011 at 5:13 PM, shitake83 <shitake83 at googlemail.com> wrote:
> Thanks for participating this much in the thread.
> But im still stuck with the same problem. Cant somebody write up a real
> small clustering map with lets say three features and no
> "super-duper-complicated-not-to-understand Code" like the one in the
> examples.
> Theres no real writeup, just "use this" and it should work. No it doesnt.
> Thanks soo much.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Vector-Feature-Clustering-tp6474651p6483204.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Best Regards,
Christian Ledermann
Nairobi - Kenya
Mobile : +254 702978914
If you save the living environment, the biodiversity that we have left,
you will also automatically save the physical environment, too. But If
you only save the physical environment, you will ultimately lose both.
1) Don’t drive species to extinction
2) Don’t destroy a habitat that species rely on.
3) Don’t change the climate in ways that will result in the above.
