[OpenLayers-Users] OpenLayer & iPhone
Mohammed Malaka
MMalaka at imgs.ie
Tue Jun 21 11:47:06 EDT 2011
Hi
Thanks for your reply.
I downloaded the Openlayer 2.11. library. Copied the OpenLayer.js from
the build folder and copied the theme & img folder.
I changed my code to :
<html><body>
<div id="demoMap"></div>
<script src="OpenLayers.js"></script>
<script>
map = new OpenLayers.Map("demoMap");
map.addLayer(new OpenLayers.Layer.OSM());
map.zoomToMaxExtent();
</script>
</body></html>
The performance slightly better (8 seconds) on the iPhone. But the
Andriod is still better 3-4s..
Regards
Mohammed
-----Original Message-----
From: Andreas Hocevar [mailto:ahocevar at opengeo.org]
Sent: 21 June 2011 16:41
To: Mohammed Malaka
Cc: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] OpenLayer & iPhone
two things to do:
1) Don't use http://www.openlayers.org/api/OpenLayers.js - this is a
full build (you need less than 10% of what it contains), hosted on a
slow server.
2) Instead, build your custom OpenLayers.js with only what you need and
host it on your server along with the app. See
http://docs.openlayers.org/library/deploying.html for instructions.
Andreas.
On Jun 21, 2011, at 17:10 , Mohammed Malaka wrote:
> Hi All,
> I am working on a .Net Mapping web application for Mobile that use
OpenLayers.
> I created the following simple page
> <html><body>
> <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
> <script>
> </script>
> </body></html
> This pages take about 10s to load on the iPhone 4.3.3 (using Safari
browser) and about 3-4s to load on Andriod 2.3 HTC desire HD (using the
default browser).
> why it is slow on the iPhone?
> Any advice on how to improve the performance?
> I tried the 2.11 release and I get the same results.
> Regards
> Mohammed Malaka
> Sr. Applications Engineer, IMGS
> 8b Keypoint, Rosemount Business Park, Dublin 11
> t: +353 1 885 3839
> w: www.imgs.ie e: mmalaka at imgs.ie
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
