AW: [OpenLayers-Users] passing html string to popup
Arnd Wippermann
arnd.wippermann at web.de
Sat Jun 25 14:26:44 EDT 2011
if you know the argument "tweet" from your evt.feature, then the below code
should work:
function onFeatureSelect(evt)
selectedFeature = evt.feature;
tweet = ...;
popup = new OpenLayers.Popup.FramedCloud(
"chicken",
evt.feature.geometry.getBounds().getCenterLonLat(),
null,
popupHTML(tweet), //returns the html string
null, true, onPopupClose);
evt.feature.popup = popup;
map.addPopup(popup);
Arnd
_____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Nicholas
Efremov-Kendall
Gesendet: Samstag, 25. Juni 2011 18:34
An: users at openlayers.org
Betreff: [OpenLayers-Users] passing html string to popup
Hi all,
I'm currently creating popups and populating their html content with the
following code
{selectedFeature = evt.feature;
"chicken",
null,
"<div style='font-size:.8em'>User Name: " +evt.feature.id + "</div>",
null, true, onPopupClose);evt.feature.popup = popup; map.addPopup(popup);}
rather than pull out the attributes myself, I'd like to pass in a preformed
html string via a variable, but I'm not sure how to do this, and I currently
lack a sufficient knowledge of jscript syntax to research this. I can form
an html string via this function but I'm not sure how to pass it back to the
popup function above...
function popupHTML(tweet) {
var retval = '';
retval += '<div class="tweet_info">';
retval += '<img alt="' + tweet.from_user_id + '" src="' +
tweet.profile_image_url + '" class="tweet_profile"/>';
retval += '<h3>' + tweet.from_user + '</h3>';
retval += '<p>' + tweet.text + '</p>';
retval += '<p>Source: <a href="' + tweet.source + '"/>' +
tweet.source + '</a></p>';
retval += '</div>';
return retval;
thanks again in advance...
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110625/d86d33cb/attachment-0001.html
