AW: [OpenLayers-Users] passing html string to popup
Arnd Wippermann
arnd.wippermann at web.de
Sun Jun 26 06:31:27 EDT 2011
Hello Nick,
in your plotTwt function you create a feature without attributes. Most
likely is this the cause of the error. Perhaps you need only to add the line
twtfeat.attributes = tweet.attributes;
function plotTwt(tweet){
var twtfeat = new OpenLayers.Feature.Vector(tweet.point);
tweetz.addFeatures(twtfeat);
Arnd
_____
Von: Nicholas Efremov-Kendall [mailto:n.e.kendall at gmail.com]
Gesendet: Samstag, 25. Juni 2011 21:20
An: Arnd Wippermann
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] passing html string to popup
Hi Arnd,
Thanks, that worked, but I've hit another stumbling block. I'm probably
messing up here somehow, but I tried passing in tweet to the function like
so
function onFeatureSelect(evt, tweet)
{selectedFeature = evt.feature;
popup = new OpenLayers.Popup.FramedCloud(
"chicken",
evt.feature.geometry.getBounds().getCenterLonLat(),
null,
popupHTML(tweet),
null, true, onPopupClose);evt.feature.popup = popup; map.addPopup(popup);}
which now returns an error 'cannot read property of 'from_user_id' of
undefined, which means that the html is being fed into the popup, but that
the info from the json object is being passed in. Full code is below, again,
sorry for my novice questions...
var feat, OpenLayers, latlon;
var tweetz = new OpenLayers.Layer.Vector("Tweets", {styleMap: new
OpenLayers.StyleMap({externalGraphic:
"OpenLayers-2.11-rc1/img/marker-green.png", pointRadius: 10})});
var marker = new OpenLayers.Layer.Vector("Marker", {styleMap: new
OpenLayers.StyleMap({externalGraphic: "OpenLayers-2.11-rc1/img/marker.png",
var map = new OpenLayers.Map('map');
var tweets = [];
var tweetsQ = [];
var refreshQuery = '?=';
// Need something here for popups or marker lables
function onFeatureUnselect(evt)
{map.removePopup(evt.feature.popup);evt.feature.popup.destroy();evt.feature.
popup = null;}
//Map features and so forth
function initGIS(){
map.addControl(new OpenLayers.Control.LayerSwitcher());
var mapnik = new OpenLayers.Layer.OSM();
map.addLayer(mapnik);
map.addLayer(tweetz);
map.addLayer(marker);
tweetz.events.on({
'featureselected': onFeatureSelect,
'featureunselected': onFeatureUnselect
selectControl = new OpenLayers.Control.SelectFeature(tweetz,
{clickout: true, toggle: false,hover: false}
map.addControl(selectControl);
selectControl.activate();
map.setCenter(new OpenLayers.LonLat(-90, 38).transform(new
OpenLayers.Projection("EPSG:4326"),map.getProjectionObject()),12);
$(document).everyTime('30s', acquireTweets);
$(document).everyTime('100ms', parseTweetsQ);
getLoc();
function getLoc(){
if (Modernizr.geolocation) {
navigator.geolocation.getCurrentPosition(plotLoc,handle_error);
} else {
yqlgeo.get('visitor',norm_yql_resp);
function createTWTsrcURL (){
var temp = map.getCenter().transform(new
OpenLayers.Projection("EPSG:900913"),new
OpenLayers.Projection("EPSG:4326"));
return 'http://search.twitter.com/search.json' + refreshQuery + '&geocode='
+ temp.lat +'%2C' + temp.lon + '%2C50km&rpp=100&callback=?';
function plotLoc (position){
var feat = new OpenLayers.Feature.Vector(new
OpenLayers.Geometry.Point(position.coords.longitude,position.coords.latitude
).transform(new
OpenLayers.Projection("EPSG:4326"),map.getProjectionObject()),14);
marker.addFeatures([feat]);
var bounds = marker.getDataExtent();
map.setCenter(bounds.getCenterLonLat(),10);
acquireTweets();
function acquireTweets(){
$.getJSON(createTWTsrcURL(), function(data){
if(data.results)
$.each(data.results, function(i, tweet){
if (tweet.geo || tweet.location)
tweetsQ.push(tweet);
});refreshQuery = data.refresh_url;});}
function parseTweetsQ(){
if (tweetsQ.length > 0) {
var tweet = tweetsQ.pop();
if (tweet.geo){
var lon = tweet.geo.coordinates[1];
var lat = tweet.geo.coordinates[0];
tweet.point = new OpenLayers.Geometry.Point(lon,lat).transform(new
OpenLayers.Projection("EPSG:4326"),map.getProjectionObject());
//tweet.attributes = {};
plotTwt(tweet);}}}
function popupHTML(tweet) {
var retval = '';
retval += '<div class="tweet_info">';
retval += '<img alt="' + tweet.from_user_id + '" src="' +
tweet.profile_image_url + '" class="tweet_profile"/>';
retval += '<h3>' + tweet.from_user + '</h3>';
retval += '<p>' + tweet.text + '</p>';
retval += '<p>Source: <a href="' + tweet.source + '"/>' +
tweet.source + '</a></p>';
retval += '</div>';
return retval;
function onPopupClose(evt)
selectControl.unselect(selectedFeature);
"chicken",
null,
popupHTML(tweet),
On Sat, Jun 25, 2011 at 1:41 PM, Nicholas Efremov-Kendall
<n.e.kendall at gmail.com> wrote:
Thanks Arnd!
Will give it a shot.
On Sat, Jun 25, 2011 at 1:26 PM, Arnd Wippermann <arnd.wippermann at web.de>
wrote:
if you know the argument "tweet" from your evt.feature, then the below code
should work:
function onFeatureSelect(evt)
tweet = ...;
"chicken",
null,
popupHTML(tweet), //returns the html string
Arnd
_____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Nicholas
Efremov-Kendall
Gesendet: Samstag, 25. Juni 2011 18:34
An: users at openlayers.org
Betreff: [OpenLayers-Users] passing html string to popup
Hi all,
I'm currently creating popups and populating their html content with the
following code
"chicken",
null,
"<div style='font-size:.8em'>User Name: " +evt.feature.id + "</div>",
rather than pull out the attributes myself, I'd like to pass in a preformed
html string via a variable, but I'm not sure how to do this, and I currently
lack a sufficient knowledge of jscript syntax to research this. I can form
an html string via this function but I'm not sure how to pass it back to the
popup function above...
var retval = '';
retval += '</div>';
return retval;
thanks again in advance...
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110626/66077b53/attachment-0001.html
