[OpenLayers-Users] Function to create a geographically correct
circle
Janis Elmeris
janis.elmeris at intelligentsystems.lv
Tue Jun 28 09:33:45 EDT 2011
It would be a good idea to add this function to
OpenLayers.Geometry.Polygon along with createRegularPolygon that is
already there. Something like createGeodesicRegularPolygon as there is
getGeodesicArea.
Janis
On 2011.06.06. 8:20, Michael wrote:
> Regular Polygons are fine for many applications. I needed range rings
> for ocean races, which did not correctly reflect the projection of the
> map. Although it projected like a nice round circle, the correct
> shape should have been oval.
> Did not find a geographic circle function in OL, so I adapted one from
> one found online.
> I present it here should anyone want it, or have a better idea, or
> want to point out that this was in OL all along.
> *function GeoCircle(latin, lonin, radius)// thanks to VE site for
> basic algo. Returns an OL Polygon of diameter in nautical miles
> var locs = new Array();
> var lat1 = latin * Math.PI/180.0;
> var lon1 = lonin * Math.PI/180.0;
> var d = radius/3440.07;// change this value to the radius of the
> Earth in your units
> var x;
> for (x = 0; x <= 360; x+=6) //gives 60 points. More than enough
> for a smooth circle most likely
> var tc = (x / 90)* Math.PI / 2;
> var lat =
> Math.asin(Math.sin(lat1)*Math.cos(d)+Math.cos(lat1)*Math.sin(d)*Math.cos(tc));
> lat = 180.0 * lat / Math.PI;
> var lon;
> if (Math.cos(lat1)==0)
> lon=lonin; // endpoint a pole
> else
> lon = ((lon1 - Math.asin(Math.sin(tc) *
> Math.sin(d)/Math.cos(lat1)) + Math.PI) % (2 * Math.PI)) - Math.PI;
> lon = 180.0 * lon / Math.PI;
> var loc = new pt(lon,lat);
> locs.push(loc);
> var poly = new OpenLayers.Feature.Vector(new
> OpenLayers.Geometry.Polygon(new OpenLayers.Geometry.LinearRing(locs)));
> return poly; //this can be added to a map
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110628/2e65a735/attachment.html
