[OpenLayers-Users] AW: [mapserver-users] "Low-resolution" raster
image problem when usingOpenlayers
Arnd Wippermann
arnd.wippermann at web.de
Tue Jun 28 14:28:12 EDT 2011
use some image viewer to get information of your images.
tile_topleft_remote.png is a 8bit image (256 color image), where only 45
colors used.
tile_topleft_local.png is a 24bit image (16,7 Mill. colors), where 13274
colors used.
The requests ask for map_imagetype=png. So it seems, that your mapfiles are
different, because the response of the servers delivers a different image
for the same imagetype. Or do you use different MapServer versions?
The problem has to be an issue with MapServer and not with OpenLayers.
Arnd
_____
Von: kensei3000 [mailto:kensei3000 at yahoo.com]
Gesendet: Dienstag, 28. Juni 2011 04:32
An: Arnd Wippermann
Cc: users at openlayers.org
Betreff: Re: AW: [mapserver-users] "Low-resolution" raster image problem
Hi Arnd,
Thanks a lot for the tip. I copied the image url of the top-left most tile
for both local pc and remote server tests.
Here is what I got:
Local:
http://localhost/cgi-bin/mapserv?map=%2Fopt%2Fmaps%2Fsandbox%2Fmapserver_ope
nlayers_if%2Fsample.map&layers=sample_raster&mode=map&map_imagetype=png&mape
xt=-90+0+0+90&imgext=-90+0+0+90&map_size=256+256&imgx=128&imgy=128&imgxy=256
+256
Remote:
http://remotehost/cgi-bin/mapserv?map=%2Fopt%2Fmaps%2Fsandbox%2Fmapserver_op
enlayers_if%2Fsample.map&layers=sample_raster&mode=map&map_imagetype=png&map
ext=-180+-90+0+90&imgext=-180+-90+0+90&map_size=256+256&imgx=128&imgy=128&im
gxy=256+256
The only significant difference of the two urls appear to be the 'mapext'
and 'imgext' parameters. When I checked the resulting images after inputting
the urls in the browser, I noticed that the tile images had different sizes
and positions. I believe this was due to the said parameters. I tried
changing the 'mapext' and 'imagext' parameters of the server test url to
match that of the local test url, and indeed the size and position of the
remote server tile image changed. However, I am still unable to figure out
what causes the color distortion or "downsampling" of the image in the
remote server.
For further reference, I've attached the tile images I got using the above
urls.
Here is the openlayers code I used. It is the same for both local and remote
server tests except for the host in line 18.
//sample.html
1 <html xmlns="http://www.w3.org/1999/xhtml">
2 <head>
3 <style type="text/css">
4 #map {
5 width: 1024px;
6 height: 768px;
7 border: 1px solid black;
8 }
9 </style>
10 <script
src="http://openlayers.org/dev/lib/OpenLayers.js"></script>
11 <script type="text/javascript">
12 <!--
13 var map, layer;
14
15 function init(){
16 map = new OpenLayers.Map( 'map' );
17 layer = new OpenLayers.Layer.MapServer("World Map",
18 "http://localhost/cgi-bin/mapserv",
19 {map:
'/opt/maps/sandbox/mapserver_openlayers_if/sample.map', layers:
'sample_raster'});
20 map.addLayer(layer);
21 map.zoomToMaxExtent();
22 }
23 // -->
24 </script>
25 </head>
26 <body onload="init()">
27 <div id="map"></div>
28 </body>
29 </html>
And below is the common .map file I created with the help of the Quantum GIS
Mapserver Export tool.
The raster image has an associated World file (.wld) for georeferencing.
1 # Map file created from QGIS project file
/var/maps/sandbox/mapserver_openlayers_if/sample.qgs
2 # Edit this file to customize for your map interface
3 # (Created with PyQgis MapServer Export plugin)
4 MAP
5 NAME "QGIS-MAP"
6 # Map image size
7 SIZE 8180 4930
8 UNITS meters
9
10 EXTENT -86.515507 -50.290979 88.076495 48.225271
11 PROJECTION
12 'proj=longlat'
13 'ellps=WGS84'
14 'towgs84=0,0,0,0,0,0,0'
15 'no_defs'
16 END
17
18 # Background color for the map canvas -- change as desired
19 IMAGECOLOR 255 255 255
20 IMAGEQUALITY 95
21 IMAGETYPE jpeg
22
23 # Legend
24 LEGEND
25 IMAGECOLOR 255 255 255
26 STATUS ON
27 KEYSIZE 18 12
28 LABEL
29 TYPE BITMAP
30 SIZE MEDIUM
31 COLOR 0 0 89
32 END
33 END
34
35 # Web interface definition. Only the template parameter
36 # is required to display a map. See MapServer documentation
37 WEB
38 # Set IMAGEPATH to the path where MapServer should
39 # write its output.
40 IMAGEPATH '/tmp/'
41
42 # Set IMAGEURL to the url that points to IMAGEPATH
43 # as defined in your web server configuration
44 IMAGEURL '/tmp/'
45
46 #Scale range at which web interface will operate
47 # Template and header/footer settings
48 # Only the template parameter is required to display a map. See
49 TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
50 END
51
52 LAYER
53 NAME 'sample_raster'
54 TYPE RASTER
55 DUMP true
56 TEMPLATE fooOnlyForWMSGetFeatureInfo
57 EXTENT -86.515507 -50.290979 88.076495 48.225271
58 DATA 'sec_field.jpg'
59 STATUS DEFAULT
60 TRANSPARENCY 100
61 PROJECTION
62 'proj=longlat'
63 'ellps=WGS84'
64 'towgs84=0,0,0,0,0,0,0'
65 'no_defs'
66 END
67 END
68
69 END
Hope you could provide further assistance.
Ken
_____
To: 'kensei3000' <kensei3000 at yahoo.com>
Sent: Tuesday, June 28, 2011 1:53 AM
Subject: AW: [mapserver-users] "Low-resolution" raster image problem when
usingOpenlayers
hi,
if you do a right click on a tile to get the context menu, you should be
able to copy the url (if the tiles of your server is the most top of the
visible layers). Compare the different urls. If you load them in your
browser you should get a response for a single tile from your server.
Perhaps that gives you an idea, what goes wrong.
Arnd
_____
Von: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von kensei3000
Gesendet: Montag, 27. Juni 2011 05:37
An: mapserver-users at lists.osgeo.org
Betreff: [mapserver-users] "Low-resolution" raster image problem when
usingOpenlayers
Hi!
I am trying to use MapServer as a WMS layer in Openlayers. I setup the
MapServer in our server machine, using my own PC as the test client. I
created a simple .map file in our server that contains one raster image.
Using the mapserver tool 'mapserv' in a URL string, I was able to load the
output map with full resolution correctly in a browser (Google Chrome).
However, when I tried to load the map using a simple Openlayers script
(HMTL) which I created on our server (accessible via browser), the map image
appeared to have a much lower-resolution (i.e. 256-colors only) and was
pixelized. Also, I could see white lines representing the tile edges of the
map.
I did another test. This time, I installed MapServer in my own PC. I created
a .map file similar to the one I used in our server, with the same raster
image. I created a similar Openlayers script (HTML) in my own PC, but this
time it would call the MapServer from my own PC. I loaded the script using a
browser and the image displayed correctly with full resolution.
Does anyone have an idea what the problem could be?
I would appreciate any help in this matter.
Thanks in advance! :)
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110628/5219af9a/attachment-0001.html
