RV: [OpenLayers-Users] Openlayers & IE6 performance problem/error
Andreas Hocevar
ahocevar at opengeo.org
Wed Mar 2 07:05:55 EST 2011
Hey Ingo,
the issue can also be reproduced with the Post layer examples that OpenLayers ships with.
Regards,
Andreas.
On Feb 21, 2011, at 19:19 , Ingo Weinzierl wrote:
> Hi David,
> I have just tried to open the demo you've provided. But there is
> just a blank screen without any content. Firebug tells me, that
> there are resources placed at 192.168.3.14 which can't work for me
> ;-) Can you repair the example, so that I can watch the problem on
> your site? This would be nice for me before I start searching for
> the problem.
> Regards, Ingo
> On Wed, Feb 16, 2011 at 12:47:03PM +0100, David Alda Fernandez de Lezea wrote:
>> Hi again, after doing some tests I can confirm that this happens also in IE7 and IE8. Any ideas/suggestions will much appreciated.
>> ________________________________
>> De: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] En nombre de David Alda Fernandez de Lezea
>> Enviado el: martes, 15 de febrero de 2011 13:09
>> Para: openlayers-users at lists.osgeo.org
>> Asunto: [OpenLayers-Users] Openlayers & IE6 performance problem/error
>> Hi there,
>> We've finally achieved publishing our OpenLayers based GIS web application for our customers with GeoServer in the back-end. Everything works fine, well, almost .We've noticed that there is a worrying issue that affects navigation through the map when a SLD is applied to a WMS layer. This issue appears when the user opens the web application with IE6 and drags the map quickly. It seems that IE goes crazy, and shows the typical generic error message of javascript. If you click on yes button it shows the Just In time debugger and the execution stops in the folowing line:
>> For adding this layers on the fly I use this piece of code:
>> addWMSLayer: function(layerName,labelName,owsUrl, imageFormat){
>> //HACK IE
>> if (this._BROWSER_NAME == "Explorer"){
>> var layer = new OpenLayers.Layer.WMS.Post( labelName,owsUrl,{layers: layerName, format: imageFormat, transparent: 'true'},{maxExtent: new OpenLayers.Bounds(460000, 4690000, 610000, 4820000),'buffer': 0, visibility: true,isBaseLayer: false, units: 'm', reproject: false, opacity: 0.8} );
>> layer.transitionEffect = 'resize';
>> this.map.addLayers([layer]);
>> }else{
>> var layer = new OpenLayers.Layer.WMS( labelName,owsUrl,{layers: layerName, format: imageFormat, transparent: 'true'},{maxExtent: new OpenLayers.Bounds(460000, 4690000, 610000, 4820000), 'buffer': 0, visibility: true,isBaseLayer: false, units: 'm', reproject: false, opacity: 0.8} );
>> Then I apply some SLD's generated on the fly with the following code
>> applyStyleToLayer: function(layerName,estilo){
>> if (estilo.SLD)
>> this.map.getLayersByName(layerName)[0].mergeNewParams({SLD: estilo.SLD});
>> else if (estilo.SLD_BODY)
>> this.map.getLayersByName(layerName)[0].mergeNewParams({SLD_BODY: estilo.SLD_BODY});
>> else if(estilo.STYLES)
>> this.map.getLayersByName(layerName)[0].mergeNewParams({STYLES: estilo.STYLES});
>> You can test the behaviour through this URL:
>> http://www.iktlan.net/mapa/generaMapa.asp?sesion=AAD1058_19&ambito=MUNI
>> I'm using OpenLayers version 2.9.1.
>> Thanks in advance.
>> Un saludo,
>> David Alda Fernández de Lezea
>> Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
>> IKT
>> Granja Modelo s/n · 01192 · Arkaute (Araba)
>> Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
>> email: dalda at ikt.es web: www.ikt.es
> Content-Description: ATT196656074.txt
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Users mailing list
> Ingo Weinzierl | ++49-541-335083-0 | OpenPGP key: 0x2D2E2573
> Intevation GmbH, Neuer Graben 17, 49074 Osnabrück | AG Osnabrück, HR B 18998
> Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
> Users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
