[OpenLayers-Users] pan while drawing
Eric Lemoine
eric.lemoine at camptocamp.com
Tue Mar 8 03:39:04 EST 2011
Hi
Since two weeks or so OpenLayers (trunk) allows panning the map while
drawing. This change affects every scenario involving drawing
geometries on the map (see the links below). Getting the "pan while
drawing" code right hasn't been easy, and there still may be bugs here
and there. We would really appreciate if people could test the new
drawing tools, ideally in real applications. To test the current trunk
you can use <http://www.openlayers.org/dev/OpenLayers.js>.
Thanks a lot,
<http://www.openlayers.org/dev/examples/draw-feature.html
<http://www.openlayers.org/dev/examples/measure.html>
<http://www.openlayers.org/dev/examples/snapping.html>
<http://www.openlayers.org/dev/examples/split-feature.html>
<http://www.openlayers.org/dev/examples/SLDSelect.html>
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
