[OpenLayers-Users] Re: Offline usage of openlayers
Charles Galpin
cgalpin at lhsw.com
Thu Mar 10 19:01:26 EST 2011
This looks like I was going to suggest - run a web server using portable apps (this many even be based on it). Done properly I don't think they would even know there is a web server and possibly even a database running.
http://portableapps.com/
charles
On Mar 10, 2011, at 6:57 PM, Phil Scadden wrote:
>> I have a client that needs to have a map solution running offline, and
>> no internal webserver. run it as file based.
> I've done a lot of work on this. Depends on how much functionality you
> want. TMS, Image work fine. The moment you get into queries and vectors,
> it gets tough. WFS is out. Chrome is hopeless. Its security model wont
> let you use ajax so its a real struggle to get KML,GML (your only vector
> options) in. You have to make heavy use of tag injection to get JSON in.
> Other browsers are okay with KML/GML but they need to be small as they
> are slow to load. you might like to look at
> http://developmentseed.org/blog/2010/oct/02/maps-stick-version-2-released.
